06-19-2018 03:31 PM
07-07-2018 02:14 PM
Darkmattr wrote:
I recently decided to fix my g46vw that had a broken screen and missing hard drive... While putting everything back together I managed to break the connector off of the keyboard connector board... I first thought i would just need a replacement keyboard but none of them come with the dang connector board... I found others on this forum with the same issue but that was over two years ago and the estore no longer has this item in stock... I also have had zero luck on ebay.. I just spent $200 fixing this laptop and am not keen on giving up... So I could REALLY use some help finding this product.. I believe the model number is either 90R-NMMCB1000Y or 60-NMMCB1000-C01... They look identical and on a part store I saw that they are both compatible but can anyone confirm this?
Also does anyone know what the cord that connects from this module to the motherboard is called? Looking at mine it looks a little messed up on the connection to the keyboard side so I would just assume buy another one if possible... Any help or guidance would be extremely appreciated as I am at a standstill here...!
08-28-2018 11:19 AM
11-30-2018 01:27 PM
12-03-2018 08:07 PM
Darkmattr wrote:
Anyone at all have a tip on how to find this part? its driving me absolutely nuts!
02-15-2019 10:51 AM
11-23-2019 11:18 AM
12-21-2023 01:36 AM
I have a g46vw that needs this same board
12-25-2023 06:11 PM
Give this site a try for what you need
12-26-2023 09:34 AM
https://www.asus.com/us/support/customer-self-repair/
This link takes you to asus self repair
