The cable transferring the actual data to the LCD got more width - about the same size as the battery connector - and its socket is near the right fan ( when the laptop is sitting infront of you like normal work ).
look here & here.
Please please please make yourself a favor - and WATCH THESE LINKED TEARDOWN MOVIE, inorder to understand what is what - SO YOU MIGHT AVOID SCREWING-UP your G751.
back to your image...
that looks like a wifi antenna connector - and it sits around the LCD in the monitor unit.
worst case scenario - when you connect that cable back to the wifi module and boot up OS, you won't have good reception.
you can always DIY - buy such cable inc connector, or just soldier an extention to the small wire+connector you've already ripped off the screen.
note that wifi antenna best sit in the monitor due to various shielding design asus made in advance - but you can always make trial & error if you don't want to open up the monitor part to insert the wifi antenna. ( you can drill a hole in the shell to have a tail out of the laptop - again - worst case ).
Asus G751JTSamsung EVO 850 120GB + 1TB HDD 7200RPM
Cleaned installed Win 10 HOME
My Guides:
- [POST=538713]ROG LAPTOPS: COMPLETE DRIVER LIST ![/POST]
- [POST=538713]How to install windows 8/8.1/10 on any UEFI supported laptop the PROPER way[/POST]
- [POST=538711]HOW TO (EASILY!) UPGRADE FROM WIN7 SP1/8.1 WITHOUT GOING THROUGH THE UPGRADE PROCESS ITSELF ![/POST]
- [POST=605307]HOW TO REMAP FN+KEY AND SPECIAL BUTTONS: "STEAM", "ROG" & "SHADOWPLAY"[/POST]
- [POST=539663]Win 10 x64: SETUP USB @SUPERSPEED, NO HANG-UPS! | ACCELERATES USB 3.0/2.0 TRANSFER RATE SPEED TWICE![/POST]
