Results 1 to 2 of 2
    ROG Guru: White Belt Array
    Oct 2013
    90
    Trying to breath a bit of life back into a RIV-E system. CPU Advice
    My uncle is my gaming buddy but is quite stubborn. I had a pair of 980s in SLI, one failed and both were replaced with 1070s. The 980s were already too much GPU for the HTPC they resided in so I thought I'd pass the 1070s off to my Uncle and confiscate his 970 for my HTPC. The goal was to convince him to upgrade his motherboard and CPU (Rampage IV-E+i7 3820) but that's where his stubbornness comes in. My only solution is to drop in the best CPU I can and hope for improvement though I know there's still going to be some bottle necking. Don't even get me started on the i5vsi7 discussion with him, he must have an i7.
    At first I thought the obvious choice would be to snag a 3770k but after looking around at some prices I might be able to do better/equal for cheaper. A buddy in our IT department thinks he can find a Xeon 1650/1660 or 2643 which would be similar to the 3960X/3970X. I know that's wasted because the majority of work load on this PC would be in the single thread performance though there is some drone video editing done on occasion. It looks like a 3770k will run me in the ~$150 range and a Xeon will cost roughly $100-$125. He also said he could probably find the 8C Xeons(2667-2687) but would be a tad more than the 3770k so not sure if that's worth it though they may run cooler.
    There is another alternative. I do have a Maximus VII Formula I could put him in but I'd still need to source a CPU. The concern there is cooling. He keeps his tower trapped inside the slot in his desk with the door shut so ventilation isn't very good. My experience with 4770k/4790k temps tells me that's not a viable solution.
    MAIN RIG:
    Maximus X | i7-8700k | 32GB Corsair Vengeance | 2x EVGA 1080ti FTW3 | EVGA Supernova G3 1000 | Corsair Air 540 | Corsair H115i | 2x Samsung 850 Pro 256gb | 2x WD Black 4tb | Corsair HD series Fans x6 | Corsair Commander Pro
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    498
    13,501
    3770K is LGA 1155 not 2011
    Get a 3970X and OC it...4.6GHz on a decent AIO cooler....
