big problem!! in hwmonitor it says my cpu thermal saftys are off how do i turn on
AlwaysWinter
i dont want my cpu's thermal safety's to be off how do i turn them back on? mild oc 48x and 47x avx offset 3 however because of this i have seen my temps running as high as 100c wth. tryin to keep it under 70c 75c is the most im comfortable with and i have a very good case corsair 9fans
i have the latest bios 8700k cpu z370 hero maximus
Asus Hero Maximus Z370, intel 8700k Corsair c16-18-18-36 vengence 3200mhz 750evga PSU rx580gpu
Rob_W_
Level 12
Check in your bios under monitor tab, see what it is set at in there.
AlwaysWinter
under the monitor tab it only has qfan and monitor or ignore wich all is set to monitor. i do have a fan plugged into the spot reserved for a pump but doubt that disabled the cpus saftys
AlwaysWinter
i always get terrible support for asus rog products on the forums why? i think the vccio and system agent cpu voltage is way off when set to auto. these automaticly disabling thermal saftys with no easy way to find them in the bios really concerns me can any techs help?
