Ryzen 7 1800x build problems Please Help
dj5436
To start i here is a full list of my components. Ryzen 7 1800x, Asus Crosshair vi Extreme, GSkills TridentZ 4 x 8gb 32gb total 2400mhz this is qlv certified, Asus GTX 1070ti OC , corsair hx1000i, and a Samsung 860evo 500gb with a clean install of windows 10. My problems all started with a ram issue were all sticks were being found in the bios but only the half that is in the A slot would go to the total system memory. talked to Asus and ended up doing an rma on the motherboad. mother board came back no faults. after this i got a second 32gb ram kit that was still qvl certified. the problem was still there for about 36hrs at that point i gave up and had other things to do came back about 12hrs later and the ram problem solved itself. But now i am getting very low fps even getting fps dips just in windows. in fur mark i average about 15fps or lower (normally lower). i was able to test with a friends computer that is not on ryzen and my gpu works gust fine in his system. i also tested my power supply and ssd on his system and it all worked fine. As far as i could tell the only thing left was the cpu so i sent a rma request to amd they replaced my processor (they just replace it and do not do any testing). just got the new on and installed it in my system, and i am still getting extremely low fps. any one have any ideas on what could be going on i have tried different bois versions and driver versions currently on latest for both.
Retired
Not applicable
How many watts does your power supply have? Manufacturer?
hi dj5436,
Don't know if this will help but I found out that the top gfx slot on the Asus crosshair hero vi (yes, I know it's different), has issues with the M.2 slot. I run 2 970s in SLI and with gfx output from the top card I get Nvidia errors of "No Nvidia GFX components installed" or sumsuch. Hope this is relevant.
Mark.
