Results 1 to 4 of 4
    New ROGer Array
    Jun 2018
    2
    ROG G20CI M.2 max capacity with newest 1402 bios - solved?
    Hello fellow ROG experts,
    I have a G20CI with a 512GB m.2 and would like to upgrade to the Samsung PRO 2TB M.2
    Does any one know if this will for sure work now with the latest 1402 bios?
    Thanks
    New ROGer Array
    Jun 2018
    2
    Quote Originally Posted by detsoob View Post
    Thanks
    To answer my own question yes the Samsung Pro 2TB M.2 MZ-V6P2T0BW does indeed work on the Asus ROG G20CI with the 1402 bios.
    A little bit of bios tweaking is required in order for Windows 10 Pro to recognize the 2TB M.2
    The bios recognizes it right away.
    ROG Enthusiast Array
    Feb 2016
    27
    Does this apply to the G20CB model, does anyone know?
    ROG Guru: Yellow Belt Array Welsh Whoopee's Avatar
    Jan 2016
    17
    227
    Quote Originally Posted by ChairmanMeow View Post
    my best would be that size ssd would need a bios update to a old pc like the G20CB and Asus hasn't have one for ages
    YOUTUBE CHANNEL @ http://bit.ly/2LNo1dI
    ASUS ROG G20 PLAYLIST @ http://bit.ly/2R9njXC
