Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    New ROGer Array
    Jun 2018
    1
    Exclamation Bios is updating led firmware !!
    hello guys, i'm in trouble with my crosshair vii.
    the problems start with some bad shutdown after turning off windows. motherboard don't shutdown.
    few days later when i turn on the pc i have this message "bios is updating led firmware, do not shutdown....", since i trried everything. Flash new bios 0702. clear cmos. remove bios battery. flashback recovery with bios 0207 and the other bios. nothing work.
    i can boot to windows if i wait enough (1h) but if i reboot or turn off again the "bios is updating led firmware"
    Maybe bios is corrupted? any idea?
    (sorry for my bad english)
    edit : my setup, windows 10 64 bit, 2700x, 16Go gskill
    ROG Guru: Brown Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    103
    1,017
    i) Reference below image, when on UEFI 0702 are your version numbers same?
Name:	UEFI 0702 Mobo page.jpg
    ii) Do you use AURA/any other RGB SW?
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme Alpha - G.Skill Trident Z 3400MHz C14 QC - RX VEGA 64
    R5 3600 - Custom WC - Asus Crosshair VII Hero Wifi - G.Skill Ripjaws V 3800MHz C16 - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
    ROG Member Array REA Electric PC Specs
    MotherboardASUS ROG CROSSHAIR HERO VII (WIFI)
    ProcessorAMD 2700X
    Memory (part number)CORSAIR LPX 3000MHZ 16GB KIT
    Graphics Card #1ASUS ROG STRIX GTX1070 OC 8GB
    Storage #1NVME SUMSAUNG 950 PRO 255GB
    Storage #2SEAGATE 2TB RAID ARRAY
    CaseTHERMALTAKE P3 WHITE
    Power SupplyCORSAIR RM750I
    REA Electric's Avatar
    Oct 2018
    13
    x470 Crosshair Hero (WIFI) Same issue LED Firmware Update Boot delay
    Same problem...
    BIOS is updating LED firmware. Do not shut down or reset the system to prevent system bootup failure.
    After 30 to 40 minutes System Boots.
    Reinstalled latest Aura Lighting Software no change ;-(
    Have reported issue to ASUS support so far no response...
    Reflashed BIOS no change..
    Will add an image BIOS and LED info once I able to boot BIOS... what a pain..
    This there a method similar the aura_update_v01_c6h LED FW flash tool for the X470 C7H LED FW?
    LED EC1 Version is Blank????
    Now have done a clean install of Windows 10 Pro Version 1809
    Allow ASUS Grid to update drivers Version 1.05.35
    AURA Now launch with the following error
    Reflashed BIOS
    Clean Install of Windows 10 Pro
    Installed Drivers and AURA software from ASUS Grid
    No Joy...
    On Power up or reboot
    gupsterg PC Specs
    Processori5 4690K
    MonitorAsus MG279Q
    Storage #2HGST 2TB
    gupsterg's Avatar
    Feb 2015
    103
    1,017
    If I was in your shoes I'd flash a very old UEFI using flashback. As this would contain older versions of ASUS EC/LED firmware, it should instigate a reflash of each; then I would flash to latest UEFI, again using flashback.
    ROG Member Array
    Aug 2018
    6
    Hi
    Had this all the time oc ram, had to turn PSU off and up the ram voltage and basically get stable.
    ROG Guru: White Belt Array
    Nov 2014
    18
    113
    Can someone with this error run this tool (cmd or power shell as administrator), save their firmware and send it to me for debug?
    https://1drv.ms/u/s!Atmpv-6qHr_6o5VTCdY06POPk1JSBA
    aura82_update.exe -s myfw.bin
    You can also try updating to this firmware: https://1drv.ms/u/s!Atmpv-6qHr_6o5VHvIdLs5KJpiPC8Q
    Note: This is not any official procedure and is done at your own risk
  7. #7
    ProcessorAMD 2700X
    Oct 2018
    13
    LED FIRMWEARE ISSUE X470 no joy
    Quote Originally Posted by elmor View Post
  8. #8
    ProcessorAMD 2700X
    Oct 2018
    13
    LED FIRMWARE ISSUE X470 no joy
    No joy... ;-( LED EC2 Version Blank.....
    My System still works fine once booted but No AURA Lighting Effects and takes 30 minutes to boot.
    I'm going to arrange an RMA return to ASUS via my supplier. This is a pain as I live in a Regional area and the store I purchased the Motherboard is a fair distance away so if I wish to return the Motherboard I will need to take a whole day off to do so. I could arrange a courier or postal return but this will take several days. I'm also not happy about having to teardown my system to remove the Motherboard. Was updating to 1001 BIOS a big mistake... YES
    Have now tried to downgrade BIOS to 0801 but no joy at all, the damage has been done... Also have tried the latest beta BIOS as a last ditch attempt.. ;-(
  9. #9
    ProcessorAMD 2700X
    Oct 2018
    13
    BIOS 1001 Update and AURA LED DISASTER
    My System still works fine once booted but No AURA Lighting Effects and takes 30 minutes to boot with Bios is updating led firmware Message....
    Have checked hardware all connectors appear okay. No issues before BIOS 1001 Update...
    Last edited by REA Electric; 10-31-2018 at 12:44 PM. Reason: Added more information
  10. #10
    ROG Member Array
    Oct 2018
    8
    I continue to be plagued by this problem of a 30 minute wait to re-boot while the "LED firmware updating" message is displayed.
    I disabled the Aura lights in the BIOS on the mobo since I am not interested in them. It occurred to me that perhaps I must have them enabled for the never ending firmware update to complete. However, it's a Catch-22 since I am never given an opportunity to access the BIOS via the "delete" key. One can't access the BIOS while this firmware update is running (or waiting, or whatever it is doing). After 30 minutes the mobo finally continues and boots the operating system.
    Can someone suggest a way I can break into this cycle and access the BIOS? Perhaps by enabling the Aura lights, the firmware update will complete and I can rid myself of this annoying problem.
