Dear members,
I recently bought a GT5300 Rapture router because i wanted all the features i needed in one device, and especially the amount of Gbps LAN ports.
But i have a serious problem regarding the LAN ports, i can't set up a 1Gbps connection with my router.
The maximum speed i can connect with is 100Mbit / Half Duplex.
This is very strange because i don't have this problem when connecting to my Gbps LAN switch (Netgear S8000), using the same cable and system setup.
Anyway these are all the things I've done / tried.
- Visually checking all the LAN ports of the asus router
- Measured out my cable connection with a RJ45 LAN tester (all pin connections where live)
- Restored factory settings
- Downgraded firmware from 3.0.0.4.384.21045 => 3.0.0.4.384_20287
- Updated my driver LAN Gbps motherbord driver & BIOS
None of the above delivered any result, on my S8000 everything works fine but when switching to the router LAN port i can't connect with 1Gbps speed, only 100mbit/half duplex.
System setup
- Windows 10 Pro x64 Spring Update Eng Version
- Asus X99 Rampage V Motherbord
- Asus 1080Ti strix GPU
- i7 5840 CPU (4.2Ghz)
- 16GB 3200Mhz G.skill RAM
- 512GB Samsung 960 Pro SSD
LAN setup
- CAT5e wall mounts
- CAT6 Cable
- Asus Router Rapture GT5300
- IPS WAN router connected with CAT5e cable to asus router WAN port.
Anyway i hope you guy's can help me, any settings i need to change in the router setup?, or anything because i'm getting ready to send this thing back!
Regards and thx in advance
Freezera
