Results 1 to 5 of 5
    New ROGer Array
    Jun 2018
    1
    Exclamation Any video tutorials or advice when reapplying thermal paste? Temperature issues.
    Hi guys, I want to reapply thermal paste as I have been running into some temperature issues. I did undervolt but did not help as much as I thought it would. I do not want to damage my computer in anyway so any video tutorial links or advice would be helpful. I did open it up but I saw some frightening sparks caused by some goop from the heatsink, likely glue. I have an Asus ROG GL502VM.
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(4) SSD's - Samsung 960 & 970 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    48
    1,126
    There are so many videos on Youtube for applying thermal paste I wouldn't know where to begin. My suggestion is do a Youtube search, and then view several before making any decision on moving forward.
    Davemon50
    ROG Guru: Orange Belt Array Snakeyes's Avatar
    Dec 2012
    42
    276
    "Frightening sparks"?
    When, where and how?
    Keep in mind application method can change with different materials. Make sure you check the YouTube's (as suggested) for the appropriate brand.
    NAME THE SANDWICH: – White Bread, Lots of Baloney, Russian dressing and served with a small pickle.?
    Intel Core i7 8700K @5.1 Stable Delidded
    Asus Maximus X Code
    16 GB
    G skill TridentZ DDR4 ​4266 (PC4 34100)
    Corsair HX1000i digital
    EVGA 1070 GTX TiSuperclocked+
    Samsung NVMe SSD 960 pro M. 2
    Samsung 860 Pro
    Watercooled with EK block radiator fans etc.
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,112
    just a lill dott ( rice size ) on the middle of the CPU, take off the plastic cover on the CPU cooler ( if its stil on ( yeah ppl have done this before ) ) and place cooler back on and clamp it down.
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    127
    1,853
    There are a few different approaches, I tend to coat a thin layer across the heat spreader with the applicator provided with brands like Thermal Grizzly.
Tags for this Thread
