Results 1 to 2 of 2
    ROG Member Array Juggla PC Specs
    Juggla PC Specs
    MotherboardAsus z97 pro wifi ac
    ProcessorIntel 4790k 4.8 1.3v 4.9 1.35v
    Memory (part number)Gskill 1600cl9 @ 2200 10-10-11-26
    Graphics Card #1R9 280 SAPPHIRRE Dual-x
    Graphics Card #2Sapphire 7950 Dual-x
    Sound CardOnboard
    MonitorVizio 42" 1080p TV
    Storage #12X 850 EVO 512GB 1 is M.2
    Storage #22x Seagate Barracudas 2tb
    CPU CoolerCustom loop 2x240 Rads 4 120mm Fans
    CaseAntec 900
    Power SupplyCorsair RM1000i
    Keyboard Logitech K330 wireless
    Mouse Logitech wireless
    Headset/Speakers 5.1 Logitech
    OS Windows 10 pro
    Network RouterBelkin n450
    Accessory #1 Swiftech MCP-50X Pump Primoflex tubing
    Accessory #2 Phobya UC-1 Extreme Brass Waterblock
    Accessory #3 Xbox wireless reciever & PlayNcharge Xbox
    Jul 2018
    What is V1 in hwinfo64 on asus z97 pro wifi ac?
    I've noticed in hwinfo64 in the sensors page is V1 and it looks to be one of my vcore settings because it is the only sensor that drops to like ~ .8 volts at idle and way over my set vcore at load. For example my vcore in bios is set at manual static voltage of 1.261, and on the core sensors it goes to 1.28 which is fine because my mobo overvolts a tiny bit. but on this V1 sensor it goes up from .8 idle to 1.36 Vcore!!!
    I've googled this V1 readout and I found maybe 2 forums that really did'nt answer the question what is V1. One website I think the author said to ask Asus.
    In the attachment pic you can see v1 sensor under the Asus EC: Aii section.
    All c-states and speedstep are disabled.
    Asus z97 pro wifi ac motherboard
    Im just concerned of that sensor because I can do 4.9ghz stable on my haswell at 1.315vcore the cores go up to 1.344 but this v1 sensor says over 1.4 volts at this setting.
    Juggla PC Specs
    Sound CardOnboard
    CaseAntec 900
    OS Windows 10 pro
    Jul 2018
    So now until I figure this out I have to wait at 4.6 1.176 vCORE and its spiking to 1.3?
Tags for this Thread
