Results 1 to 2 of 2
    ROG Enthusiast Array Zfast4y0u's Avatar
    Jan 2018
    40
    EK T-splitter possible issue
    hello, i just bought T splitter from EK and noticed inside of it is not fully painted and there is some wierd discoloration on non painted part inside. not sure is it corrosion or something else. here are pics, need advice should i use it or RMA.
    https://imgur.com/a/jKlhdcf
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    21
    1,475
    That look like corrosion. I think EKWB offered some cheaper version of splitters with imperfections or little scratches, but not inside.
    They report as cosmetic imperfections. But this look to me as corrosion.
    You can't remove that with cotton swab and alcohol?
    Now I google and on other sites I saw similar marks as yours.
    I have X Spliter and it's shine from inside.
    You need to contact EKWB because I saw and on other pictures similar as your but smaller. On black splitters.
