Need help with proper values for 3000mhz kit for 3200mhz OC
Nepty
Hi.
I have tried several times to OC my 3000MHz HyperX Predator 64GB Kit to 3200MHz, the system isn't stable even with higher voltage.
There must be some other settings than needs to be tweaked in order to be stable.
I tried to ask Customer Support, but they wanted me to check QVL for supported memory kit.
MOBO | ROG MAXIMUS XII FORMULA
CPU | Intel i9-10850K
COOLER | Corsair iCUE H115i ELITE CAPELLIX's)
RAM | G.Skill Trident Z DDR4 64GB 3200Mhz (3800MHz OC) (F4-3200C14D-32GTZR)
GPU |
ASUS ROG Strix LC RTX 4090 OC
HDD |
Kingston FURY Renegade e M.2 2TB
PSU |
ASUS ROG THOR 1200
CASE |
ASUS ROG Strix Helios White
OS |
Windows 11 Pro 64bit
Monitor |
Asus 48'' 4K PG48UQ x2
Nate152
Hi Nepty
1) Set your ram manually
2) Dram voltage 1.40v
3) CPU VCCIO voltage 1.20v - 1.25v
4) CPU System Agent voltage 1.20v - 1.25v
How does she go ?
Nepty
Hi.
Thanks for the suggestion, I'll try that later today! 🙂
Let you know if it works.
GPU |
HDD |
PSU |
ASUS ROG THOR 1200
CASE |
OS |
Monitor |
