07-05-2018 03:50 AM - last edited 3 weeks ago by ROGBot
07-05-2018 09:20 AM
Zammin wrote:
Hi everyone
I have just finished dialing in a 5Ghz overclock on my Maximus X Code and 8700k with an AVX offset of -1.
I've just noticed that for some reason my AVX offset is coming on and off during games. When I run Prime95 26.6 the clock speed stays at 5Ghz, when I run Cinebench it stays at 5Ghz, but I've just started playing Overwatch and I can see it jumping between 4.9Ghz and 5Ghz constantly. This still occurs even when i set my power plan to High Performance in Windows 10. I remember this happening earlier in the year on my Maximus X Hero and reading that is was bugged at the time. As far as I know most games shouldn't be using AVX..
Does anyone know how to fix this?
I am on the latest BIOS for the MX Code. To see BIOS screenshots of my settings check out my other thread here: https://rog.asus.com/forum/showthread.php?103546-Looking-for-some-help-understanding-LLC-and-advice-...)
Thanks!
07-05-2018 02:11 PM
Silent Scone wrote:
I'd be first asking Blizzard if anything in Overwatch makes use of the instruction set, because a lot of games these days actually do.
07-05-2018 10:22 PM
07-06-2018 01:00 AM
Zammin wrote:
Well I've just tested CS:GO and Fortnite and the exact same thing is occurring. CS:GO seemed to trigger it less while Fortnite seems to trigger it more frequently. Would an old DX9 game like CS:GO really use AVX? I'm stumped.
07-06-2018 12:12 AM
07-06-2018 03:02 AM
Raja@ASUS wrote:
When we spoke to Intel about some of the AVX quirks, and there was one reply that stated a lot more applications use the code than people realize. Apparently, some Net Framework apps/utilities do, too. If apps like that are on the system, you may see the AVX ratio being enforced more frequently than expected.
07-06-2018 03:05 AM
07-06-2018 05:54 AM
Raja@ASUS wrote:
I've pitched some stuff to Intel about AVX offset, but it takes up to five years for features like this to be changed. It's a long process. They are aware of some of the limitations.
