07-07-2018 03:19 AM
08-10-2018 03:39 AM
darkcypsyan wrote:
heya,
i've just installed a fresh windows10 on a SSD to remplace the original HDD on my FX53VD i just got.
everything was fine until i started using the USB charger + software, it was working while using the original windows10 on the HDD but not anymore (been using the same usb port as before).
the asus support can't seems to help me as they asked for the laptop to be return to an Asus center (and of course there is none in my country and i don't want to ship it oversea and wait for weeks (slow post office here)).
does anyone has an idea as to why this software don't work?
at the same time but lot less important is that the windows store say that my device is not compatible to install Asus Giftbox 😕
thanks
09-16-2018 07:47 PM
darkcypsyan wrote:
heya,
thanks
09-18-2018 10:04 AM
luisjsd wrote:
I have fix that problem installing the ASUS USB Charger Plus Service 5.0.4, donwloaded from that site: https://ivanrf.com/en/latest-asus-drivers-for-windows-10/ . I downloaded, from Microsoft Store, the USB Charger Plus utility (from ASUSTeK Computer) at the same time.
I don´t know if it is working because I have downloaded both utilities or if just that v5.0.4 works. I preffer don't try to find out.
Hope you all can fix that guys.
11-17-2018 10:11 PM
02-15-2024 05:55 PM - edited 02-22-2024 11:18 AM
I have the same problem. USB Charger + has a 'problem with the installer' in Task Manager. I can't get into the program to delete it. Please help!
*edit: I want to completeley remove it.
