Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    ROG Guru: Green Belt Array Phillyflyer's Avatar
    Mar 2012
    30
    536
    8086k 5.3ghz overclock
    Finally managed to get the 8086k overclocked to 5.3 ghz and prime 95 stable with an 8 hour run. using bios 1503. Chip has been dellided with a copper heatsink and ambient temp at the time was 22 celcius. Vcore was set @ 1.425V with LLC 6 with the GSkill Trident Z 3866 MHZ running 1.35v with a VCCIO set @ 1.15v and VCCSA set @ 1.15v .
    Asus ROG Maximus XI EXTREME
    Intel i7 9900K OC'D @ 5.2 GHZ @ 1.345V (1.296V LOAD) LLC 6 PRIME 95 STABLE 8 HRS
    XSPC RX360 Rad (6)Scythe Gentle Typhoon 1850 RPM Fans In Push/Pull @ 1500 RPMS
    Swiftech Drive II / Swiftech MCP35X Pump
    Enermax Platimax 1200 Watt Power Supply
    32GB G.Skill F4-3866C18Q-32GTZR 3866 MHZ CL18 1.35V (OC 4266MHZ 17-18-18-41-2T @1.45V)
    MSI GTX 1070 SEA HAWK EK X SLI WITH ASUS HB RGB
    (5)Samsung 840 Pro 128 GB In Raid 0
    (2) WD 1TB Black Edition
    Corsair 900 D
    ROG Member Array runningdodo PC Specs
    MotherboardMaximus X Formula
    Processor8700K@5 GHz
    Memory (part number)2*16 GB GSkill 3600 MHz (F4-3600C17-16GTZR)
    Graphics Card #1GTX 1080 Ti
    Sound CardEssence STX 2
    Monitorsamsung 850d
    Storage #1Samsung 960 Pro 512 GB
    Storage #2Samsung 960 Evo 500 GB
    CPU CoolerAquacomputer Kryos XT
    Power SupplybeQuiet Dark Power P9 850 W
    Dec 2017
    21
    Nice run, congrats!
    How high is VRM-Temp going up under full load with prime@1,44 V Vcore?
    Mar 2012
    30
    536
    Dunno what vrm temp was when I tested bios 1503 at that time....New bios 1603 is now out...so...trying that now with same settings....vrm temp with bios 1603 reading 67 degrees and looks like a nice drop in core temps under full load Prime 95 thus far.
    Corsair 900 D
    ROG Guru: Yellow Belt Array kaptanedi PC Specs
    kaptanedi PC Specs
    Motherboardmaximus viii formula
    Processor6700k
    Memory (part number)16gb
    Graphics Card #1gtx980 kingpin
    Storage #1samsun 950 pro
    Storage #2corsair force 3 120gb
    CPU Coolerek xtx360+xtx240 64mm
    Casecorsair c70
    Power Supplycorsair ax860i
    Keyboard logitech g710+
    Mouse logitech g502
    OS win 10 64bit
    Jul 2013
    20
    156
    Quote Originally Posted by Phillyflyer View Post
    prime 95 which run the test.
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    Phillyflyer,
    Very nice, is your memory kit 2 or 4 stick kit?
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,832
    Good CPU you've got there.
  7. #7
    Mar 2012
    30
    536
    Quote Originally Posted by Menthol View Post
    Phillyflyer,
    Thanks Menthol...it's a 4 stick matched kit.
    Corsair 900 D
  8. #8
    Mar 2012
    30
    536
    Quote Originally Posted by Silent Scone View Post
    Thanks Silent Scone
    Corsair 900 D
  9. #9
    ROG Member Array
    Dec 2016
    11
    Nice overclock. Is PLL Bandwidth and VTT on auto?
  10. #10
    ROG Member Array ftln46 PC Specs
    ftln46 PC Specs
    MotherboardAsus ROG Z370-I Strix
    ProcessorIntel Core i7 8086K
    Memory (part number)F4-4000C19D-32GTZSW
    Graphics Card #11080 TI
    MonitorASUS ROG Swift PG279Q
    Storage #1NVME PCIe 2 x 1024TB
    CPU CoolerH110i
    CaseNZXT MANTA
    Power SupplyCorsair HX650
    Jul 2018
    24
    P95 with AVX or without ?
