Results 1 to 7 of 7
    ROG Junior Member Array Buzzkiller PC Specs
    Buzzkiller PC Specs
    MotherboardROG Crosshair VII Hero Wi-Fi
    ProcessorRyzen 7 2700x
    Memory (part number)F4-3200C14D-16GTZR
    Graphics Card #1EVGA GTX 1080Ti SC Black Edition
    MonitorDELL S2716DGR
    Storage #1Samsung 960 evo 256gb
    Storage #2Samsung EVO 850 512gb & 860 EVO 1tb
    CPU CoolerEK Supremacy AMD
    CaseFractal Design Define R6
    Power SupplyEVGA 850 G3
    Keyboard G.Skill KM780 RGB
    Mouse Logitech G503 Proteus Spectrum
    Headset HyperX Cloud II
    Mouse Pad Paul's hardware desk mat
    Aug 2017
    3
    CH7 W_PUMP+ controls lost
    After updating to the latest uefi/bios (0702) I can no longer change the speed on the W_PUMP+ header like I can with all the other fan headers. I have the options for PWM mode, DC mode, or disable (I think there's one other option in there but I can't recall at the moment). Previously when I had it set to PWM mode I could set parameters for low temp, mid temp, and high temp and what rpm % to run at each, but now it just sets the pump at 100% and all the options are gone. I can't even change the curve in Q fan control. Is it the same for everyone else? Was there a reason these settings were removed, or plans to bring them back?
    ROG Guru: Blue Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    79
    845
    Had been meaning to reply for a while, but had my C7H not in use.
    Currently on UEFI 0804. When I changed the W_PUMP+ header control from [Disabled] to another setting, I needed to press the down arrow to see the settings. The screen does not auto scroll down.
Name:	W_Pump+ controls.jpg
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme Alpha - G.Skill Trident Z 3400MHz C14 QC - RX VEGA 64
    R7 2700X - Custom WC - Asus Crosshair VII Hero - G.Skill Ripjaws V 3533MHz C14 DC - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
    Buzzkiller PC Specs
    Aug 2017
    3
    Quote Originally Posted by gupsterg View Post
    Thanks, I'll.update bios when in get my machine back up and running then check it out.
    Buzzkiller PC Specs
    Aug 2017
    3
    Bios update fixed it. Thanks!
    ROG Member Array
    Sep 2015
    7
    Quote Originally Posted by Buzzkiller View Post
    Hello. What's bios version do you use?
    I update to 0805 .. but cant change value.
    ROG Enthusiast Array Zefram PC Specs
    Zefram PC Specs
    MotherboardAsus ROG Crosshair VII Hero
    ProcessorAMD Ryzen 7 2700X
    Memory (part number)G.Skill Trident Z RGB 32GB (4x8GB) F4-3600C18D-16GTZRX
    Graphics Card #1Asus ROG Strix 1080Ti OC Edition
    MonitorAsus PG279QZ 165Hz & VG248QE 144Hz
    Storage #1500GB Samsung 970 EVO
    Storage #24TB Western Digital
    CPU CoolerCorsair H150i
    Power SupplyCorsair RM850x
    Keyboard Logitech G710+
    Mouse Logitech G502 Proteus Spectrum RGB
    Headset Sennheiser Gaming One
    Mouse Pad Razer Goliathus Control
    OS Windows 10 Professional
    Network RouterNetgear N600
    Accessory #1 Blue Yeti Blackout Microphone
    Zefram's Avatar
    Nov 2018
    33
    31
    They released 2304 last night.
  7. #7
    Jun 2018
    45
    OFFTOPIC:
    I use a D5 Pump...but its Vario. However it has a PMW cable....
    Can someone tell me where i can connect it, and what options i use on Bios to activate it? I presume its only for monotorise rpm`s..
Tags for this Thread
