Sound Issue-Headset vs RVIE sound card
Marko911
Hi there...I tried to connect my Logitech G933 Artemis Spectrum headset with 3,5mm cable (rear line in port),and I get sound only on one side.It works fine on aorus gaming 9 and my phone.Is there any settings or whatnot that I should look into? Thanks in advance for your help.
Bramax
It seems a misscontact or you have earphone settings to output sound only on one channel.
Try to insert jack 5-10 times rapidly in the headphone socket or check audio settings in Windows.
Marko911
All settings are ok,I have selected "speakers (realtek high definition audio)"
I've used other headphones same problem..
