Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    ROG Member Array
    Jun 2017
    17
    Undervolting help for my gl502vm
    I have an ASUS ROG Gl502VM with i7 7700 hq and GTX 1060. It showed high temps while playing games like pubg upto 90C+. So i read on the forums that it was on of the persistent issues which requires undervolting so i decided to give it a try and oh boy did it exceed my expectations on GPU. The temps dropped from 80+ to 60-65 while playing PUBG. Oh boy and did the CPU break all the expectations the CPU did not drop the temps and instead started showing spikes of upto 98C on only 2 cores while the other two were atleast 20C below. After I turned off TURBO the temp spikes stopped but the temps were still high upto 88C. I need help on how to properly undervolt and need some help on what i m doing wrong. Attached is all my settings and the temps at idling which show spikes.
    Please note- The temp spikes are only on 2 of the 4 cores. So the temp spikes are also due to these 2 cores.
    CPUID- https://gyazo.com/ff1f33fcddcc1c3898c955de4ca9c44f
    TS- https://gyazo.com/0536ff2f389bcfffdcca1b05120eb717
    TS FIVR- https://gyazo.com/5526510e7f58f339108aa3f3d381eb20
    Help me out
    ROG Member Array
    Jun 2016
    18
    how on earth did you manage to drop gpu temps so low?
    btw did you try to use intel xtu instead of ts?
    undervolt to -125mV and lower turbo boost short power max to 40 - 45W
    ROG Member Array
    Jun 2017
    17
    Quote Originally Posted by dasBOT View Post
    I used ts. If u want to see my voltage curve I will send u a SS. But one more thing I opened the laptop and two of the washers of the screws holding the heatsink on CPU were broken from the laptop. Is there a way I can fix this and is this connected in anyway the high temps on 2 of the cores are related to the broken screws?
    ROG Member Array
    Jun 2017
    17
    Also on games like CS the GPU maintains 50-60C but the CPU is above 70
    ROG Member Array
    Jun 2016
    18
    Quote Originally Posted by mehul.mishra12 View Post
    yes please if you can msg me with a ss, do you get this temps with fans on 100%?
    ROG Member Array
    Jun 2017
    17
    Yes the fans are on 100%. I have switched off my laptop so will send tomorrow
  7. #7
    ROG Member Array
    Jun 2016
    18
    hello m8
    any chance for that custom gpu curve?
  8. #8
    ROG Member Array
    Jun 2017
    17
    hello m8
    Sry bro. I had some work to do so i forgot.
    Here is my curve- https://gyazo.com/ec9fdb7b221ae36af64a7503dfcb6caf
  9. #9
    ROG Member Array
    Jun 2016
    18
    interesting ... thx i will test it
  10. #10
    ROG Enthusiast Array
    Jan 2017
    33
    I hope I can help with my experience on this track to lower temps.
    After so much testing. I discover that disabling Turbo via Windows Power Manager to 99% does not work as expected. It disables TURBO however temperature dropping is not high as expected.
    The only thing which worked for me so far was disabling TURBO via Throttlestop on that option box but also disable the SpeedStep feature on the box at the right. Kept also the uV active by using -0.150mV for both Core and Cache.
Tags for this Thread
