Results 1 to 2 of 2
    New ROGer Array
    Jun 2018
    2
    GL502VS Weird double screen issue? Maybe overheat realted..
    Hi.
    When playing games on my GL502VS I get the issue on the attached images.
    I only seem to get this when playing ARK, have noticed my GPU and CPU are hitting 80c when this is running.. after a while the GPU driver crashes and eveything is back to normal..
    https://imgur.com/a/Cte1QJu
    Laptop is only about a month old..
    ROG Guru: Orange Belt Array FULLMETALJACKET7's Avatar
    Mar 2018
    46
    492
    80c shouldn't cause any problems.
    Try underclocking (not overclocking) the gpu memory and gpu core and see if it goes away.
