07-12-2018 06:32 PM - last edited on 03-06-2024 08:28 PM by ROGBot
07-12-2018 07:29 PM
07-13-2018 09:32 AM
chevell65 wrote:
Coil whine usually has more to do with power delivery that is does with hardware. Quite a few complaints about the higher end GPU's having coil whine but replacing the GPU doesn't usually seem to fix it.
It seems apparent that you would have a better chance of fixing the issue by using a different power supply rather than replacing the GPU.
