Results 1 to 4 of 4
    New ROGer Array
    Jul 2018
    3
    Exclamation Power on failed after power loss on X470-F ROG STRIX
    Hello,
    Motherboard model: ROG STRIX x470-F Gaming
    UEFI Version: 4011 x64
    CPU: Ryzen 2700X
    Memory kit part number (s) and amount in GB: GSills FlareX 3200Mhz CAS 14 2x8Gb dual channel
    GPU: Gigabyte 970 GTX
    SSD/HDDs/Optical drives:
    PSU: Corsair 750W
    CPU Cooler: Wraith
    Operating system: Microsoft Activated yes/no?
    W10
    Drivers Installed (include version): Latest Asus
    Any third Party temp/voltage software installed: No
    System Overclocked (provide details)? Defaut in BIOS with DOCP memory @ 3200Mhz
    Issue:
    I have setup in advanced tab, Restore AC Power Loss to Power On, but when power shutdown and then restore, computer doesn't boot.
    I tried with Last power state and it work a bit better, it restarts computer, but if my PC is in sleep mode and power loss happened, it doesn't restart computer.
    Any idea ? BIOS bug or am I doing something wrong ?
    Thank you in advance,
    Veronika
    New ROGer Array
    Jul 2018
    3
    Help :)
    UP !
    Please help me
    ROG Member Array
    Jul 2018
    7
    You might want to check the new bios version 4018, you're using 4011. It will reset the setup.
    Personally, I prefer the original version 0225 due to high CPU voltage in latest ver.
    New ROGer Array
    Jul 2018
    3
    I tried to update bios but issue remain the same
Tags for this Thread
