Results 1 to 8 of 8
    ROG Guru: White Belt Array Rippin Kittin PC Specs
    Laptop (Model)Lenovo Ideapad Y700 14"
    MotherboardROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K - Coffee Lake
    Memory (part number)G.Skill Trident Z RGB - 33000 MHz
    Graphics Card #1GTX 1080 Ti 11GB Gaming X Trio
    Graphics Card #2GTX 1080 Ti 11GB Gaming X Trio
    MonitorASUS 27" ROG SWIFT PG279Q - 165Hz
    Storage #12 x Corsair Force GS 128GB
    Storage #21 x OCZ Vertex 460 SATA III 2,5" SSD - 480GB
    CPU CoolerCorsair Hydro 115i
    CaseNZXT Phantom 820 FullTower - White
    Power SupplyCorsair AX1600i Digital ATX Power Supply
    Keyboard Logitech G910 Orion Spectrum
    Mouse Logitech G502 Proteus Spectrum
    Headset SteelSeries SteelSound 9H with 5Hv2 USB 7.1
    Mouse Pad ADX Ultimate Gaming
    OS Windows 10 Pro x64
    Network RouterASUS RT-N66U
    Accessory #1 HTC Vive
    Accessory #2 Logitech G27 Racing Wheel
    Rippin Kittin's Avatar
    Feb 2013
    13
    112
    System Agent Voltage
    Is it OK using a system agent voltage at 1.000 together with a VCCIO voltage set at 0.976?
    I have set them manually since auto would set them up to +1.300.
    My CPU is a 8700K running 5.1 GHz @ 1.340 v.
    CPU: Intel Core i7-8700K @ 5.1 GHz || MB: ROG Strix Z370-F Gaming || Cooling: Corsair Hydro 115i
    GFX: 2 x GeForce GTX 1080 Ti 11GB (SLI) || RAM: G.Skill Trident Z RGB 32GB OC @ 3300 MHz
    Keyboard: Logitech G910 Orion Spectrum || Mouse: Logitech G502 Proteus Spectrum
    Monitor: ASUS 27" ROG SWIFT PG279Q 165Hz || PSU: Corsair AX1600i || OS: Windows 10 Professional x64
    Case: NZXT Phantom 820 FullTower - White
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,819
    If the system is stable at those settings then yes, there isn't an issue.
    Feb 2013
    13
    112
    Quote Originally Posted by Silent Scone View Post
    Ok, thanks... I was worried maybe if I had set them too low
    The system has been running great, so far... Haven't really done a stress test yet,
    just some gaming and it runs smooth. Will do a real stress today with AIDA64.
    Feb 2013
    13
    112
    By the way, this will maybe sound stupid, but I am not really familiar with System Agent Voltage and VCCIO earlier.
    What kind of symptoms are there if you should raise these voltages?
    ROG Guru: Brown Belt Array NemesisChild PC Specs
    MotherboardASUS Maximus X Hero (WI-FI AC)
    ProcessorIntel i7 8700K
    Memory (part number)G.Skill F4-3600C16D-16GTZR
    Graphics Card #1Nvidia GTX 1070 Ti FE
    Graphics Card #2Nvidia GTX 1070 Ti FE
    MonitorASUS ROG Swift PG278Q
    Storage #1Samsung 970 PRO 512GB NVMe M.2
    Storage #2WD Black 2TB 7200 RPM 64MB Cache
    CPU CoolerNZXT Kraken X42
    CaseCooler Master HAF 932 Advanced
    Power SupplyEVGA SuperNova 1200 P2
    Keyboard Logitech G910 Orion Spark
    Mouse Logitech G703 Wireless
    Headset Logitech G Pro
    Mouse Pad SteelSeries
    OS Windows 10 Home x64 (UEFI)
    Network RouterLinksys WRT1900AC
    NemesisChild's Avatar
    Sep 2011
    89
    1,788
    Quote Originally Posted by Rippin Kittin View Post
    If raised too high: failed bios overclock, windows lock up or possibly a blue screen.
    Intel i7 8700K@ 5.2GHz (Delidded)
    ASUS Maximus X Hero (Bios 1801)
    NZXT Kraken X42
    G.Skill TridentZ@ 4000MHz CL16 2x8GB
    SLI: 2x Nvidia GTX 1070 Ti FE@ 2025/2025MHz
    OS: Samsung 970 PRO 512GB NVMe M.2
    Storage: Samsung 960 EVO 500GB NVMe M.2
    Storage: 2x Samsung 850 EVO 500GB
    Storage: WD Black 7200 RPM 64MB Cache 2TB
    Feb 2013
    13
    112
    Quote Originally Posted by NemesisChild View Post
    Ok, now I was thinking if the voltages for VCCIO and System Agent were too low... (not too high). What would be the symptoms?
  7. #7
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hi Rippin Kittin
    If VCCIO and System Agent voltages are too low, you'll likely have unstable ram.
  8. #8
    Feb 2013
    13
    112
    Quote Originally Posted by Nate152 View Post
    Hi Rippin Kittin
    Ah, ok.. that's good to know.
    Thanks!
