Results 1 to 8 of 8
    ROG Member Array
    Jul 2018
    5
    HELP with RAID 0 as boot drive
    I recently built a new system using the following hardware:
    ASUS Strix x399 motherboard (BIOS 601)
    AMD TR 1950x
    32G G.Skill TridentZ RGB DD4
    2 X Samsung SSD 840 Pro 256G
    1 X WD 4T HDD 7200RPM
    First, let me say that everything works perfectly, if I set the SATA drive as AHCI, enable CSM etc…. But I’m having issues trying to install Windows 10 Pro when setting the SSD as RAID 0.
    Problems arise when I try to load the RAID drivers during the install of Windows 10 when the SSD are configured as RAID 0.
    To configure the drives, I do the following steps:
    BIOS
    Advanced Menu
    - SATA Configuration set to Raid
    - CSM Disable
    Reboot
    Advanced Menu
    - RAID Xpert2 Configuration
    - Array management
    - Create array
    - Select the 2 SSD
    - Create
    Reboot
    Windows 10 install starts up to where you select the install drive. At that point there’s no drive in the list. I select load drivers. I tried to load the RAID drivers found on the ASUS CD that came with the motherboard. First, the RAID bottom driver (appears to load), then the RAID Driver (rcraid). The second one tries to load, but the green bar keeps restarting forever. The only way to regain the computer is to power down.
    I also tried the SATA drivers (v8.2.0.29) from the ASUS website (http://dlcdnet.asus.com/pub/ASUS/mb/...9_20170809.zip) Same thing happened.
    I then tried the AMD driver _V9.2.0.70) on the AMD website (https://www2.ati.com/drivers/amd-nvm...s_9.2.0.70.exe) Same thing again.
    No matter what driver I try, it seems to lock when loading the rcraid driver.
    Am I missing something? Please HELP!
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,491
    Maybe have a look through this thread and the links given through it...
    https://rog.asus.com/forum/showthrea...ME-NVME-Raid-0
    ROG Member Array
    Jul 2018
    5
    Quote Originally Posted by Arne Saknussemm View Post
    Thanks for the info.
    I followed the instructions up to loading the rcbottom.inf & rcraid.inf drivers. It appears that rcbottom driver loads, however when I try to load the rcraid.inf driver, the green bar at the bottom just keeps re-starting over and over.
    This is really frustrating...
    ROG Guru: White Belt Array
    Feb 2012
    37
    122
    Quote Originally Posted by excalibure View Post
    Hi excalibure,
    Sorry you have problems with Raid SATA installation, my setup is with NVMe Raid (2xSamsung 960PRO) and i did not have any problems in installing W10 (following the instructions on the AMD Ryzen Threadripper NVMe Raid Quick Start Guide).
    I tried to give some sugestions to your problem, but not sure about them, i disabled the NVMe Raid array and tested to mount a SATA Raid with the very same drives you have (i have 2 840 PRO 256 GB "sleeping" in a shelf next to my table), with no results, it is missing a driver!
    It's the first time i have an AMD Threadripper setup and i thought W10 had the needed drivers for SATA raid, like it is for Intel setups.
    I will try to find the correct way to do this and will post if succeed. If you discover it, please post because i'm curious about it.
    Regards
    ROG Member Array
    Jul 2018
    5
    Quote Originally Posted by squawker View Post
    Hi excalibure,
    Regards
    thanks for following up. Pretty sure it is a driver issue and I havent been able to find the right one to make it work.
    PS nice to have 2 of those sitting on the shelf......
    Feb 2012
    37
    122
    Hi excalibure,
    Got it!!
    After all, i’m used to install raid0 drives in Intel platforms since the old Seagate hdd’s times......
    Sorry if I’m very detailed, but Threadripper is a new thing to me… so, let’s go
    In bios:
    1. Preparing
    a. Advanced > AMD PBS > NVMe Raid mode > disabled (we are installing SATA and not NVMe Raid!)
    b. Secure Boot > Windows UEFI mode
    c. CSM > disabled
    Save and restart bios configs.
    d. SATA Mode: AHCI > RAID
    Save and restart bios config.
    After enabling SATA RAID Mode, RAIDXpert2 Configuration Utility appears in Advanced bios tab.
    2. Assembling the Raid array
    e. RAIDXpert2 > Array Management > Delete Array (all data, if any, is deleted)
    f. RAIDXpert2 > PhysicalDisk Management > Select Physical Disk Operations > Initialize Disks (both 840 PRO)
    g. RAIDXpert2 > Array Management > Create Array:
    Select RAID Level = RAID 0
    Select Media Type = SSD, or both
    Select Physical Disks = both 840 PRO
    Array Size: 510.812 GB (value for the 2 x 840 PRO 256 GB)
    Select Cache Tag Size = 128 kB (or 64)
    Read Cache Policy = No Cache
    Write Cache Policy = Write Back Cache
    3. Checking if raid array is OK
    Going back to Array Management > Manage Array Properties > Select Array: Array1, RAID 0, 510.8 GB, Normal!!!
    4. Installing Windows 10
    Obs: When installing W10 the WD 4T HDD should be disconnected from any SATA input, to avoid Windows installing parts of it in the HDD.
    h. prepare an USB flash drive with the following driver:
    https://support.amd.com/en-us/downlo...%2010%20-%2064
    AMD RAID Driver (SATA RAID Only) 717 KB 9.2.0.70 6/7/2018
    i. Bios > Check if the installation media with W10 (another USB flash drive or a DVD disk) is the first UEFI boot drive
    j. Normal installation until: A driver is necessary
    Choose the First driver from h item: rcbottom.inf > click OK (even if apparently nothing happens, go to the second driver!), choose and install it:
    Second driver: rcraid.inf > click OK
    Obs: on my installation it was not necessary install the Third driver (rccfg.inf) to finish W10 installation.
    I installed it after W10 was installed and the X399 Chipset driver (AMD Chipset Drivers, 65.3 MB, 18.10.0601, 6/7/2018) was also installed.
    k. Proceed with normal installation in Unit 1: Space not allocated = 475.7 GB > New > Apply > OK > Disk with 4 Partitions > advance in installation
    5. Conclusion
    After the complete W10 and the Chipset driver installations, in the Device Manager it was left a device without driver and I installed manually the rccfg.inf driver, and all was OK.
    Sorry for the lengthy post, but threadripper SATA RAID installation is new for me, and it is very different from Intel (which I am accustomed to).
    Hope this helps and regards,
    P.S. some pics:
    []'s
  7. #7
    ROG Member Array
    Jul 2018
    5
    Thanx for the full instruction. *I’m away for the weekend, but will check it out when I’m back and will advise. *I know I didn’t do step “F”, but I’m pretty sure the rest is the same.
    Your help is very much appreciated.*
  8. #8
    ROG Enthusiast Array
    Nov 2013
    28
    Problem solved using W10 18 03, and last AMD Drivers 9.2.0.87, Rufus using GPT UEFI mode, making sure each reboot that the array doesn't show anything strange, or redoing it, unplug all sata drives beforehand.
    Unless what have been said on other forum, last windows's version works.
Tags for this Thread
