Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    ROG Enthusiast Array
    Jul 2018
    11
    38
    (Solved) GM501GS questions
    I have a few question about the GM501GX-XS74.
    1. Thunderbolt 3
      • Can it run external eGPU / external enclosure for PCI-E? Yes
      • Does it support incoming power from external devices to laptop? I am aware it will not power the laptop entirely but to supplement the main power adapter. Does not support incoming, obviously.
      • What is the current limit on it? USB-C mode 5V 3A
    2. The keyboard will turn off on battery after idle but it will not power back up after connecting to AC power. I have to go to Aura settings and apply the last settings. Is there any solution for this? The firmware has been updated to the latest version. Restart "Lighting Service".
    3. On optimus mode the screen will randomly flicker. I am thinking it is a muxing issue between IGP and Nvidia. I had a the same issue with one of my old laptops and bios update fixed that issue. Is there any support place I can report this to? It is an issue existed since HD/UHD 620. Probably an Intel issue since it also exits in Linux OS. The problem does not exist in UEFI screen.
    Edit: Added photo to show the flickering
    Edit2: Marked as solved.
    Last edited by madhacker3kxl; 08-16-2018 at 09:22 PM. Reason: added photo to show flicker
    Apr 2018
    30
    I have the GU501GM, wich is the BestTry baby brother with a 1060 6gb
    1 haven't tried- -Not sure why you want to have an eGPU, as any USB-C Video adapter, with the exception of displaylink adapters will run from the GTX card
    2 notice the keyboard issue recently, I am using a semi clean windows install (used nt-lite to push in the drivers to windows 10 usb install)
    Might try a different, not sure
    3 Not sure
    Jul 2018
    11
    38
    Quote Originally Posted by egonzalez7579 View Post
    3 Not sure
    There is many reason to use eGPU even if it has gforce 1070 in it. The information is just for my curiosity. For some application I use my quadro card. I am using a clean install windows also.
    I got this laptop to replace my massive workstation. It doesnt have the power as my workstation but the form factor of the laptop is nice.
    Fun note, my last ROG laptop was G50V-A2 aka "space heater", which i still have. The ROG series has come a long way.
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,126
    You can get drivers for your notebook at Asus Support Download
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    Jul 2018
    11
    38
    Quote Originally Posted by Clintlgm View Post
    I am aware of that and does not answer anything.
    ROG Guru: Yellow Belt Array ROG_HARDCORE PC Specs
    Laptop (Model)GX501VI Zephyrus
    MotherboardROG RAMPAGE VI EXTREME
    ProcessorIntel® Core™ i9-7980XE
    Memory (part number)64GB DDR4-4700MHz Trident Z RGB
    Graphics Card #1ROG Poseidon GeForce® GTX 1080 Ti Platinum edition
    Graphics Card #2ROG Poseidon GeForce® GTX 1080 Ti Platinum edition
    Graphics Card #3ROG Poseidon GeForce® GTX 1080 Ti Platinum edition
    Graphics Card #4ROG Poseidon GeForce® GTX 1080 Ti Platinum edition
    Monitor2X ASUS ROG Swift Curved PG348Q
    Storage #12TB Samsung 960 PRO
    Storage #22TB Samsung 960 PRO
    ROG_HARDCORE's Avatar
    Feb 2016
    8
    211
    Quote Originally Posted by madhacker3kxl View Post
    It mean GFYS, and STFU. Don't aspect anything from support.
    Try using only discrete graphic mode. See if the problem persist. Else, RMA or return.
  7. #7
    Jul 2018
    11
    38
    Quote Originally Posted by ROG_HARDCORE View Post
    Chill out dude. There is no reason to be bitter about it. If you don't like something don't respond to it. Asus support is slow as snail but I got them to fix a lot of software issues; be it phones or computers. If someone else is having the same issues as me, it makes it easier to explain to them what is wrong.
    No, flickering does not happen on Discrete mode.
    People with your attitude makes people not come to these forums, ask questions, getting things solved.
  8. #8
    Apr 2018
    30
    Have you try NVidia site Drivers,
  9. #9
    Jul 2018
    11
    38
    Yes, I currently have the latest Nvidia drivers from their site installed.
  10. #10
    Feb 2016
    8
    211
    "No, flickering does not happen on Discrete mode." Problem solved.
    Answer: optimus mode doesn't work.
    Prove: Same battery life under DGPU VS IGPU. :/ Why? Fanboy engineer please explain.
    Else, Please wait for bios update. Rolling out soon on May 2019.
    People get paid to give you crap support, and product they claimed godlike. judge yourself.
Tags for this Thread
