C7H bios 804 problem with Aura and led when power off
wonderiuy
With 804 bios the setting "RGB LED Lightning -> When system is in sleep, hibernate or soft off states" is not saved if turned "Off" (or probably is restored to ok with Aura ROG app), so the LEDs are turned on when the PC is turned off.
The same setting in Aura ROG software is not kept, even if applied the settings return to "Rainbow" resulting in motherboard led always turned On after the PC is turned off.
What to do?
gupsterg
In AURA if I remember correctly there is a page/section with sync at shutdown, set that as off.
I'm using UEFI 0804 and have no issue with RGB being off when motherboard is off.
To be honest even if in UEFI you do not set the setting to have RGB off in sleep/power off states, but set AURA to switch RGB off at shutdown it will apply.
I even uninstalled AURA after RGB set as I wanted and settings are kept.
Intel Defector :eek: AMD Rebel
R9 5900X - Custom WC - ASUS Crosshair VII Hero WiFi - Ballistix Sport LT 2x16GB 3800MHz C16 - RX 6800 XT - WD SN770 2TB - 2x 870 EVO 4TB
24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
:eek: CPU Validation 5.198GHz@1.314v with 4.4GHz cache + RAM 2400MHz@1T :eek:
Da Music video
