Results 1 to 10 of 27
07-24-2018 05:50 PM #1
- Join Date
- Jul 2018
- Reputation
- 10
- Posts
- 2
What is the maximum HYPER M.2 X16 CARD we can use in 1 motherboard
Hi guys,
I need some serious recommendation. I know Intel VROC supports 20x m.2 ssd's. How can you use 20 m.2 ssd's If x299 only support 2x ASUS HYPER M.2 X16 CARD which makes 8x m.2 ssd's inside.
https://www.pcworld.com/article/3199...r-a-price.html
It is because I9 7900 cpu has only 44 pci-e lane and maximum ssd's you would use is 11. Is there any other way to use more hdd's for raid more than 11 m.2's ?
I found beautiful ASUS mainboard WS C621E SAGE I choose 2x intel 4110 xeon cpu combine 80 lanes, guess what (HYPER M.2 X16 CARD) doesn't support ASUS WS C621E SAGE therefore this option is also out of question
any ideas ?
07-24-2018 09:46 PM #2
G75rog PC Specs Motherboard R VI Apex Processor I9-7900X Memory (part number) 64GB Gskill Trident Z Graphics Card #1 AMD Radeon VII EKWB water block Graphics Card #2 Waste of PCI lanes in NVME environment Sound Card Stock Monitor LG 34" Ultra Wide3440x1440 Storage #1 4ea 960 Pro 2TB, 2ea 970 Evo 2TB Storage #2 1ea 960 Pro 1 TB, 1ea 970 Pro 1TB CPU Cooler EKWB CPU, Swiftech Res/pump, 400mm Rad Case Thermaltake View 91 Power Supply NZXT Hale 90 1200W Keyboard Logitech G910 Mouse Razer Ouroboros OS W10 64 1809, 1903, Ubuntu Linux Network Router Netgear R9000 + 4ea R9000 AP's, 10 Gb Switch Accessory #1 Hyper M.2 X16 V2 Accessory #2 10GB network via Intel 550 Nic Accessory #3 2 10GB Asustor NAS 7000 series
- Join Date
- Jan 2013
- Reputation
- 13
- Posts
- 309
The R6E might be able to do 2 Hypers and a crippled X8 GPU.
The R6A can do 1 and a half (2 drives) Hypers and a crippled X8 GPU.
I use a non raid Apex with 4 drives on the MB plus 4 on a Hyper totaling 14TB and a X16 GPU at max performance.Last edited by G75rog; 12-27-2018 at 07:22 PM.
07-25-2018 05:06 AM #3
- Join Date
- Jul 2018
- Reputation
- 10
- Posts
- 2
Thanks for your answer.
I am not fuss about games I will possibly install usb to vga port to have graphic interface to not use any pci-e lane. This will be more server, I need to use intel Vroc raid 10 and fast SSDd's such as 600p intel which no compatible issue with asus ssd 16x hyper cards.
Do you think R6E can run 3x hyper ssd with 11x M.2 ? Do you also suggest that is there any fastest port I can use for m.2 ssd whether with adaptor or not that should not be pci-e since I maxed out pci-e by using 11ss's total 44 lanes. I asked these question on asus support page but yet didn't receive any answer.
thank you.
12-27-2018 04:23 PM #4
GhostWorks PC Specs Motherboard Asus Rampage VI Extreme (1704) Processor Intel Core i9 9900X 10-Core 2066 Memory (part number) 4 x 16GB CMD64GX4M4B3000C15 Graphics Card #1 Asus Strix RTX2080 O8G Sound Card Sound Blaster X7 Monitor LG 34UM95 Storage #1 Intel Optane 900p 280GB Storage #2 Asus Hyper x16 M.2 4 x 512GB Evo 970 CPU Cooler Asus Ryujin 360 Case CORSAIR 900D CC-9011022-WW Power Supply Corsair AX1500i Keyboard Logitech G19 + G13 Mouse Logitech G903 Mouse Pad Logitech G Powerplay Headset/Speakers Logitech z906 OS Windows 10 Pro Network Router Ubiquiti Gateway Pro Accessory #1 Tobii Eye Traker Accessory #2 Asus Front Panel OC
- Join Date
- Oct 2015
- Reputation
- 11
- Posts
- 59
I have the R6E , my one Hyper 16x is the non NVMe and the other is the NVMe version , I hope I can make the non NVMe version 8x with only 2 m.2 or will 8x be fast enough to handle 4x SATA m.2 ( non NVMe m.2**) ? So the GPU can still run on 16x
In my PCIe front am hoping to have 1 GPU running at 16x
ASUS Thumderboltex 3 card is high is 4x
ASUS Hyper 16x NVMe at 16x with fully populated Samsung 970 Evo raid 0
ASUS Hyper 16x non-NVMe at 8x *with non-NVMe SATA m.2*
Hope all will work *Corsair 900D
12-27-2018 07:35 PM #5
- Join Date
- Jan 2013
- Reputation
- 13
- Posts
- 309
The Hyper X16 does NOT do SATA. The Hyper X16 supplies 4 pcie lanes to each pcie nvme ssd mounted on it provided the MB is using a 44 lane cpu.
12-27-2018 07:58 PM #6
- Join Date
- Oct 2015
- Reputation
- 11
- Posts
- 59
There is 2 versions of the hyper card one is NVMe newer version , I by accident bought the non NVMe version so
Ordered the NVMe one , seeing if I can use both *Corsair 900D
12-27-2018 08:38 PM #7
- Join Date
- Jan 2013
- Reputation
- 13
- Posts
- 309
Whatever floats your boat. Waiting for the V2 version with improved power to land on distributor shelves.
12-27-2018 09:00 PM #8
- Join Date
- Oct 2015
- Reputation
- 11
- Posts
- 59
That’s the one I got coming*
12-27-2018 09:53 PM #9
- Join Date
- Jan 2013
- Reputation
- 13
- Posts
- 309
The V2? Who did you order from?
12-27-2018 10:03 PM #10
JustinThyme PC Specs Laptop (Model) G752VY-DH72 Motherboard Rampage VI Extreme Processor I9 9940X Memory (part number) 64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17 Graphics Card #1 ASUS Strix 2080Ti O11G @ 2.1GHz Graphics Card #2 ASUS Strix 2080Ti O11G @ 2.1Ghz Graphics Card #3 ROG Nvlink Graphics Card #4 Have to feed animals Sound Card External Audioengine D1 24 bit 192kbps DAC Monitor ASUS PG348Q @ 100Hz Storage #1 Intel 905P 480GB U2 flavor Storage #2 Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1 CPU Cooler HeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS Case Phanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM Power Supply Corsair AX 1500i Keyboard ASUS Claymore Mouse ASUS Spatha, Logitech MX Master Headset Sennheiser HD 700 Mouse Pad ASUS ROG Sheath Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub OS Win10 Pro 1809 Network Router NetGear NightHawk X10 Accessory #1 NetGear Prosafe 10GBe Switch Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
- Join Date
- Nov 2013
- Reputation
- 144
- Posts
- 3,854
@ghostworks
Can you please link the non-NVMe hyperx16 card? I bought the very first model that hit the shelves and it supports NVME. There is a V2 that’s supposed to be more power efficient but that efficiency amounts to a hill of beans. I’ve heard mention but not seen one.*
@OP
Each drive takes 4 lanes hence the X16 in the name.
How many the R6E will support depends on what’s graphics you use but the best you can do is 10 drives with an old x1 or x2 graphics card for a monitor or no monitor if you set it up for net boot and remote management.*
So 3 cards, one in each of the x16 slots for 8 drives in two cards then 2 drives in the last one for a total of 40 lanes.......done. 11 is not possible.*
If you look at posts in the x299 area from a year ago searching VROC all you need is there. *Last edited by JustinThyme; 12-27-2018 at 10:06 PM.
