Pg279q - light in motion - impossible to turn back on in osd
jcloiseau
Hi all,
I troubleshooted for 40 min and I'm out of solution 😞
ISSUE: the red ring on the base and ROG logo do not light up and yes I went to OSD and it actually says ON in OSD. Summary below:
- Went to OSD, setup LOM, On: no light
- Turn off and on again: no light
- Turn off, unplug for a minute, turn on: no light
- Went to nvidia control panel, turned gsync off: no light
- Went to nvidia control panel, turned gsync on everywhere: no light
- Went to nvidia control panel, turned gsync only fullscreen: no light
- Went to OSD, used reset all= yes, LOM= yes: no light
- tried unplugging DP cable from GPU: no light
- tried 2 PC reboot: no light
> I would understand that one LED died but not the whole thing
> if that helps, I kept the screen on a vesa mount for a long time with the base safely stored, I only recently reinstalled it
PLEASE HELP ME
skydoy
Just Reset using factory reset an activate it on boot - See if it help´s
I had the reverse situation wanted to turn off all lights and i was unable.
tried thrice - not working 😞
