Results 1 to 6 of 6
07-26-2018 05:13 PM #1
- Join Date
- Jul 2018
- Reputation
- 10
- Posts
- 3
Very big dual-boot problem with Asus ROG Strix GL703GS SCAR Bios !! Help me guys !!
Hello Guys,
I have upgraded from N550JV to Asus ROG Strix GL703GS SCAR. It came with hibrid HDD, 256 GB SSD (on PCI express) and 1TB HDD.
Beside the fact that the cooling fans are always on medium load (witch is weird) I have this very BIG problem with BIOS, I will try to explain what I try to do and also upload photos.
So, at first I took out the 1tb hdd and replace it with the 256 ssd from my N550JV, win 1o preinstalled.
Rebooted the rog, entered windows, all ok so far, it sees the second ssd.
Rebooted again to select boot the other ssd (I want to keep working on my old ssd and the original for games). Hit ESC, enter bios, I see the ssd but cannot add it to boot option...
Made the standard steps, disable secure boot but I does not seems to have CSM.... save and exit, no CSM...
Disable fast boot, save, exit, same thing, no CSM.
Tried to put the 1TB hdd and install win 10. I have the USB stick with win on it, plugged the use, hit esc and I have only one option to boot. The original ssd.
If my Win 10 fails... how do I reinstall it on my system???
Photo 1: you can see the usb present with win 10 and the 1 tb hdd
Photo 2: the ssd, located on the motherboard, PCIE
Photo 3: Boot priority: only the ssd option, cannot add usb stck or second hdd
Photo 4: Secure boot disable
Photo 5: Cannot see usb, hdd in that section, CSM NOT present
Photo 6: CSM missing from advanced menu
Photo 7: Cannot see the usb on easy flash... lol...
07-26-2018 08:09 PM #2
xeromist PC Specs Laptop (Model) Intel NUC laptop LAPQC71D Motherboard ROG Crosshair VIII Dark Hero Processor AMD 5800X Memory (part number) 32GB G.Skill Ripjaws V 3600 Graphics Card #1 ROG Strix RTX3090Ti Sound Card Sound Blaster Z Monitor AORUS FV43U Storage #1 Samsung 970 Pro 512GB CPU Cooler Custom loop Case BeQuiet Dark Base Pro 900 V2 Power Supply Corsair HX1000 Keyboard ROG Strix Flare II Animate Mouse ROG Chakram X Headset Steelseries Arctis Pro Wireless Mouse Pad ROG Scabbard Headset/Speakers Logitech z906 5.1 Network Router pfSense/OPNsense
- Join Date
- Jul 2010
- Reputation
- 436
- Posts
- 8,615
Windows 10 fingerprints your hardware. So as long as a system has been activated on Windows 10 in the past you can always reinstall on a blank drive. When the installation asks for a product key you just select the option to skip it and Windows will activate after the installation is complete.
* Support disease research with Folding@Home *
< < < Click the drop-down above my avatar for my PC specs!
07-26-2018 08:25 PM #3
- Join Date
- Jul 2018
- Reputation
- 10
- Posts
- 3
07-26-2018 10:46 PM #4
- Join Date
- Jul 2010
- Reputation
- 436
- Posts
- 8,615
I'm not addressing any of those as I don't have the answers. I'm just answering your question of if you have a complete failure, yes you can reinstall.
07-26-2018 11:17 PM #5
Clintlgm PC Specs Laptop (Model) Asus G752VY DH72 Motherboard Asus Z97 Pro WiFi and /Z97 Pro A Processor I7 4790K Storage #1 512 GB M.2 Samsung 960 Pro Storage #2 1 TB Samsun 850 Pro Case Cool Master Haf OS Win 8.1 Pro and Win 10 Pro
- Join Date
- Jul 2012
- Reputation
- 111
- Posts
- 4,188
Let me try you mention that you don't have CSM, that is because your system is UEFI, not Legacy MBR. Next, in order to have a dual boot, you'll need to clean install one of the hard drives and set up the dual boot at that time. You can google dual boot you will have issues with activation trying to run 2 windows 10 on one license.
If you insist on keeping your old SSD then you'll need to remove our M.2 PCIe NVMe SSD put it up as you'll need it later and you don't want it screwed up. Before you remove your M.2 SSD copy the eSupport folder to USB drive it holds all the drivers and Asus Software for your new notebook.
Now with only your old SSD boot to the BIOS/UEFI and change the system to Legacy then you will see the CSM and no longer see fast boot or secure boot etc.
When you reboot your system may or may not boot up into windows since all the hardware drivers will be different from what you have on your old SSD if you do get it to boot into windows you'll have to install the correct drivers for everything. Also, you will have an issue with activation of windows since the windows 10 that you have on your old SSD is activated on your old computer If its a retail version you may get MS to activate over the phone if it's an OEM version of windows it's not transferable to another computer. All in all your going to have some issues and headaches and probably a few days to get everything workings correctly.
This is where that M.2 SSD you put up comes in as in the long run you'll probably end up putting it back in and reinstalling your software and then using your old SSD for programs or data,
So while what you want to do is possible will it be worthwhile or time well spent that's up to you.Last edited by Clintlgm; 07-26-2018 at 11:22 PM.
G752VY-DH72 Win 10 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
10-08-2018 07:12 PM #6
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 13
