Please post your current working memory model and setting.
edrickjk
Was thinking to create a post to help other user ,mainly to help people chose memory module working for them.
1-Ram model , capacity per dimm, number of dimm ,using xmp or not and current working setting,
2-motherboard model and bios version,
3-Cpu ,
In my case
1- Gskill F4-4266C19D-16GTZKW 4x8Gig, DDR4 4266 (PC4 34100), 19-19-19-39,wont boot at 4266;
Currently running stable at 4133MHz 18-18-18-38 2t 1.4v,used xmp but manually selected 4133,
2-Maximus x code bios 1602,
3- I7 8700k delided running at 5.0 on all core with adaptive voltage
74867
11 REPLIES 11
NarfTV
1. G.Skill f4-3600c15d-16gtz 2x8GB kit, DDR4-3600 15-15-15-35, will boot but isnt stable.
Runs stable
@3500 15-15-15-35 -1.35v DRAM 1.10/1.15 IO/SA (XMP)
@3600 16-16-16-36 -1.35v DRAM 1.10/1.15 IO/SA (XMP)
@4000 17-17-17-32 -1.40v DRAM 1.15/1.20 IO/SA (manual timings)
2. ROG Maximus X Formula Bios 1602
3. i7 8700k @5GHz / 4500 Cache Manual Voltage.
74901
1. Gskill Trident Z F4-4266C19D-16GTZSW (2 kits, 4 x 8GB)
Running at 4000MHz C16-17-17-38-2T @ 1.4V
2. Maximus X Hero bios 1003
3. I7 8086K adaptve voltage 1.376V 5.1GHz, SA/IO: 1.185V, 1.15V (hwinfo shows 1.216V, 1.184V)
PTF2000 wrote:
official Memory List by Asus
http://dlcdnet.asus.com/pub/ASUS/mb/LGA1151/ROG_MAXIMUS_X_CODE/ROG_MAXIMUS-X-CODE_MEMORY_0309.pdf
oh we are very well aware of this list, thank you for posting. But this thread is about timings and settings that do actually work for us in practice.
NemesisChild
Level 12
F4-3600C16D-16GTZR (2x8GB modules)
3866MHz@ 16-16-16-36-2T (1.385v) - Manual bios settings
Motherboard & CPU info in my sig
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
1. Gskill Trident Z F4-3600C15D-16GTZ 2x8GB kit, DDR4-3600 15-15-15-35
- Does not work on its rated XMP speed with any VCCSA/VCCIO or RAM voltage. XMP-speed gives ramtest errors, however 3200CL14 works fine which is the speed I'm running currently.
2. ROG Z370-F Gaming latest bios 1002
3. I7 8700K 1.35V 4.9Ghz / Cache 4.3Ghz, VCCIO/VCSSA: 1.10V / 1.15V
Menthol
Level 14
M X Apex, Daily settings
8700K@5.0 1.3v, Cache@4700, Memory Gskill 2x8 4266@4226 17-18-18-38-1T 1.425v (will run tighter timings or up to 4400mhz 19-19-19) CPU at 5.3, cache 5.0 1.425v using Corsair AIO cooler
but the Apex is the best OC board made, bar none
Phillyflyer
Asus maxiimus X code daily settings :
8086k @ 5.2ghz @ 1.375v or (5.3ghz @1.425v)…. Cache @ 5000 , gskill trident z rgb 3866 mhz 4x 8 oc'd @ 4133mhz 17-18-37-2t @1.425v
75162
75163
Asus ROG Maximus XI EXTREME
Intel i7 9900K OC'D @ 5.2 GHZ @ 1.345V (1.296V LOAD) LLC 6 PRIME 95 STABLE 8 HRS
XSPC RX360 Rad (6)Scythe Gentle Typhoon 1850 RPM Fans In Push/Pull @ 1500 RPMS
Swiftech Drive II / Swiftech MCP35X Pump
Enermax Platimax 1200 Watt Power Supply
32GB G.Skill F4-3866C18Q-32GTZR 3866 MHZ CL18 1.35V (OC 4266MHZ 17-18-18-41-2T @1.45V)
MSI GTX 1070 SEA HAWK EK X SLI WITH ASUS HB RGB
(5)Samsung 840 Pro 128 GB In Raid 0
(2) WD 1TB Black Edition
Corsair 900 D
75162
75163
Damn i should have bought a cooper ihs, that is some nice temp reading.
