Results 1 to 4 of 4
    ROG Member Array ViceAndVirtue PC Specs
    MotherboardAsus Maximus VI Formula
    Processori7 4790k @4.5ghz
    Memory (part number)16gb G. Skill Sniper DDR3 1866mhz
    Graphics Card #1EVGA GTX 1080 FTW2
    Storage #1Toshiba 1TB 7200rpm
    Storage #2Hitachi 1TB 7200rpm
    CPU CoolerCooler Master ML120
    CaseDIYPC Model X
    Power SupplyThermaltake TR2 600 watt
    Keyboard Logitech G710+
    Mouse Logitech Wireless
    OS Windows 8.1 Pro
    Feb 2018
    5
    Help overlocking 4790k
    I have a 4790k I bought not too long ago, to complete my wife's build. I'm just trying to find a little help and get some advice on how I should go about overclocking the cpu. I've read dozens of posts, watched a few videos, and even been on the forums, but everyone always has different ways of doing it and I'd just like a general idea of what I should do. Here's the build list, if it helps.
    i7 4790k
    Asus Maximus Formula VI
    EVGA GTX 1080 FTW2 8gb
    Thermaltake TR2 600w PSU
    3 120mm chassis fans
    Cooler Master ML120 AIO
    I've also installed real temp, real bench, and CPU-Z, to monitor and stress the cpu. I just ran a test in real bench with the cpu at 4.5ghz and voltage at 1.25v and after about 5 min (out of a 15min test) it detected instability.
    I'd like to have it overclocked at 4.5ghz or more because my wife's plays BOTW on CEMU emulator, which causes a lot of stress on the cpu. 4.5ghz is the minimum goal, but anything better would be nice. If anyone could please give me insight or work with me to get a stable overclock, it'd be very much appreciated. Also, sometimes I'll get a couple of error codes, 1 is: "whea_uncorrectable_error" or if I'm stress testing or running emulation it'll be "watchdog_clock_timeout"
    ROG Guru: Brown Belt Array NemesisChild PC Specs
    MotherboardASUS Maximus X Hero (WI-FI AC)
    ProcessorIntel i7 8700K
    Memory (part number)G.Skill F4-3600C16D-16GTZR
    Graphics Card #1Nvidia GTX 1070 Ti FE
    Graphics Card #2Nvidia GTX 1070 Ti FE
    MonitorASUS ROG Swift PG278Q
    Storage #1Samsung 970 PRO 512GB NVMe M.2
    Storage #2WD Black 2TB 7200 RPM 64MB Cache
    CPU CoolerNZXT Kraken X42
    CaseCooler Master HAF 932 Advanced
    Power SupplyEVGA SuperNova 1200 P2
    Keyboard Logitech G910 Orion Spark
    Mouse Logitech G703 Wireless
    Headset Logitech G Pro
    Mouse Pad SteelSeries
    OS Windows 10 Home x64 (UEFI)
    Network RouterLinksys WRT1900AC
    NemesisChild's Avatar
    Sep 2011
    89
    1,783
    4.5GHz should be very doable with Devils Canyon, especially knowing that the stock turbo frequency is 4.4GHz.
    I would suggest returning your bios settings to default/stock, boot into Windows and set Windows power plan to "Performance". Open CPU-Z and make note of the frequency (which be 4.4GH) and the corresponding voltage. Restart, enter the bios, set AI tweak to manual, sync all cores to 46, then set your Vcore to say 1.32v. Run RB for about an hour and monitor the temps closely, you do not want to go over 91C. If it passed RB stress testing, slowly back down the Vcore by 0.01v until it becomes unstable, then bump it up 0.01v and you should be good to go.
    Intel i7 8700K@ 5.2GHz (Delidded)
    ASUS Maximus X Hero (Bios 1801)
    NZXT Kraken X42
    G.Skill TridentZ@ 4000MHz CL16 2x8GB
    SLI: 2x Nvidia GTX 1070 Ti FE@ 2025/2025MHz
    OS: Samsung 970 PRO 512GB NVMe M.2
    Storage: Samsung 960 EVO 500GB NVMe M.2
    Storage: 2x Samsung 850 EVO 500GB
    Storage: WD Black 7200 RPM 64MB Cache 2TB
    CaseDIYPC Model X
    OS Windows 8.1 Pro
    Feb 2018
    5
    Thanks for the info, once I'm back home I'll try the settings suggested and see if it becomes stable.
    ROG Enthusiast Array mahanddeem PC Specs
    mahanddeem PC Specs
    MotherboardAsus Maximus IX Hero Z270
    Processor7700K
    Memory (part number)Corsair DDR4 3200MHz XMP
    Graphics Card #1Gigabyte GTX1080 Xtreme Gaming
    MonitorBenQ 1080p 144Hz
    Storage #1Samsung 960 EVO nvme 250GB
    Storage #2Samsung SSD 840 Pro 256GB
    CPU CoolerNoctua D15S
    CaseNZXT Phantom 410
    Power SupplyCorsair AX750
    OS Windows 10 Pro
    mahanddeem's Avatar
    Mar 2015
    34
    I had a 4790K. It did all cores 4.4GHz at 1.17v.
    4.6 needed like 1.212v.
    Set all cores to 46
    Set vcore manual to 1.25v to see how things go
    If stable, reduce voltage by 0.01v
    If it locks or crashes, up voltage by 0.01v
Tags for this Thread
