Fried? Help!
mindsignals
Our fuse tripped earlier. I have a gaming system also used as a mining rig with 5 x 1080ti cards. After the fuse tripped (which does occur every few weeks), the mobo lights are lit, but it will not attempt to power on at all. I stripped out 4 of the cards, leaving the one required. I tried swapping the 1600w G2 SuperNova with a 600w EVGA PSU to try and determine if it is the power supply or the motherboard.
At this point, it looks like it is the motherboard, but is there some other reset sequence I'm not aware of? No codes show and no power-on attempt occurs, but various LEDs are lit on the motherboard. Is there something else I can try on the Rampage V Extreme or do I need to shop for a new motherboard?
From the 600w PSU, I only hooked up the 24-pin, the 8-pin CPU, and the 8+6 pin PCI-Express for the GPU to keep the configuration as minimal as possible.
Nate152
Hi mindsignals
No q-code with another psu points to the motherboard, could try bios flashback to see if this brings it to life.
mindsignals
