Results 1 to 6 of 6
    ROG Enthusiast Array
    Nov 2015
    40
    Maximus X Formula - Temperature problem with Samsung 970 Pro M2 NVME - HELP
    Hello to all.
    I have a problem with the temperatures of my 970 pro samsung 512 GB mounted on the Maximus X Formula card. Today with this heat has touched 50 degrees. It's dangerous? risk of damaging it?
    I have not yet removed the protective plastic of the rog logo where the samsung M2 is installed ... can that be the cause?
    I heard about some sinks for m2 but my doubt is if you can insert in the slot M2 of the maximus X formula .... can you help me?
Name:	970 pro 50.JPG
    ROG Guru: White Belt Array Carlyle2020 PC Specs
    MotherboardAsus Maximus XI APEX w/o vrm heatsink
    Processor8086K/@5.0/1.26
    Memory (part number)Corsair LPX 4000 CL19@17.17.37/360/2T/1.375
    Graphics Card #1OOO RTX 2080 Ti FTW3 ULTRA
    Graphics Card #2GTX 1060
    Sound CardOOO Xonar STX modified
    Monitor21: 9 LG 34 inch / flat
    Storage #11TB 960evo
    Storage #22TB 970evo plus
    CPU CoolerNoctua NH-D15
    CaseSilverstone FT2 +200 bucks of sounddampening
    Power SupplySeasonic Prime Titanium 1000W
    Keyboard Cherry KC 1000 / OOO CORSAIR K63 + lapboard
    Mouse MX Master 2S
    Headset Sennheiser PC360 + Philips X2HR
    Headset/Speakers klipsch 4.1 pc speaker /cooling modified
    OS Win 10 64bit
    Network Routeryeah right...
    Accessory #1 Silverstone EBA01 headphone stand / black
    Accessory #2 radio Keyfob to turn on and off from Garage
    Accessory #3 Adata USB3.1 512Mb SSD @480Mb ul/dl
    Mar 2018
    17
    91
    Hi theotorm,
    NAND likes it warm. Your 370.000 IOPS certification was made at 40 degrees i believe.
    Even though HWINFO is not as flashy as your software, HWINFO will show you 2 temperatures.
    The lower one is your NAND
    The higher one is your controller
    It is not a question IF a NVME SSD will slow down because of heat. It is just a question of WHEN it will throttle down.
    This is measured normally in seconds or maybe minutes.
    And it normally is the controller overheating first.
    So......
    So you have to download software to see the controller temp first.
    then you have to descide:
    Do i want MAX transferrate and am i willing to shorten the life of my SSD?
    If yes then actively cool the controller under its throttle temp.
    (which is not loud if you spend some bucks on the fan) I suggest the beige/brown ones.
    If you are a real nerd you will use the temp sensor header to install a 3 buck temp sensor on the controller and
    then you can program the 40mm fan to only ramp up at 55 plus degrees within ASUS BIOS.
    There are VRM fan brackets you could repurpose.
    Samsung EVO controllers will throttle:
    at 60 (like my 970 evo 512 GB )
    at 70 (like my 960 EVO 1 TB)
    If you can get your SSD under its throttle temp at 100% SSD write load it will not throttle at all and write over 2 GB/s constantly in your case i believe.
    But NAND will (somewhat) age more quickly.
    Do i want MAX reliability and the slowest degradation?
    See to it to run your NAND very roughly around 40 degree IDLE.
    Disclaimer:
    All this happenes if you copy very, very big files or a boat load of files.
    I am talking waaaay over 10 GB.
    I have deinstalled my fan (after watching a Video from Gamers Nexus) and it will throttle after 35 GB constant writes from NVME SSD to NVME SSD.
    If you only have one NVME SSD and some harddrives you will seldomly (if ever) encounter this issue
    So it will not happen 99,3% of the time for a normal nerd.
    Last thing:
    Leaving protective stickers on is seldomly wise if the are on a cooling pad.
    Even on metall it will hinder the cooling functionality.
    If it is the original Samsung sticker on the SSD you can leave it on. Especially if it is the one with the copper within.
    For more information kindly visit the homepage written ony the sticker of your SSD (if i remember correctly)
    0-70 degree operating temps i belive in your case.
    Rgds
    Carlyle
    ROG Member Array
    Mar 2012
    21
    I removed the cover and did not install it. I also remove the samsung sticker before putting on my heat sink. Get your M.2 warm up.. and shut down your computer. Quickly remove the M.2. Carefully use the razor... from one corner of the sticker... carefully remove the sticker. It should come off fairly easy. Remember not to bend the sticker or any crease line to indicate the sticker has been removed before. Put the samsung sticker onto wax paper and store it in a safe place. This is when you need warranty on your SSD. YOu can put it back without anyone know its removed.
    Clean the SSD chips with thermal paste cleaning product. Then put on heat sink... Click image for larger version.
    ROG Member Array
    Mar 2012
    21
    Quote Originally Posted by Shinchan0125 View Post
    ROG Enthusiast Array edrickjk PC Specs
    edrickjk PC Specs
    MotherboardASUS ROG MAXIMUS XI EXTREME
    ProcessorIntel Core i9-9900K
    Memory (part number)F4-4266C19-8GTZKW 8gbx4
    Graphics Card #1ASUS ROG STRIX RTX 2080 Ti GAMING OC 11G
    MonitorAcer predator X34P
    Storage #1Samsung SSD 970 EVO Plus 500GB
    Storage #2WDC WDS512G1X0C-00ENX0
    CPU CoolerEK-Velocity
    CasePhantek Enthoo Luxe 2
    Power SupplyCorsair HX1000I
    Keyboard Razer blackwidow x chroma
    Mouse Razer mamba wireless
    Headset SteelSeries arctis pro wireless
    Mouse Pad Razer Goliathus Control Extended
    Headset/Speakers Razer nommo chroma
    OS window 10
    Network RouterAsus RT-AC-5300
    Jul 2018
    30
    There lots of misinformation and misunderstanding when it come to m.2 drive .I would suggest you to watch this video,at 06:15 to put it simple nand should be warmer and the controller is the only part that actually need cooling.
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Did you remove the heatsink on the PCH chip? If you did I would not recommend doing that, a case fan mounted in the direction of the M.2 heatsink will do a good job of removing the heat
