08-04-2018 06:01 AM - last edited 3 weeks ago by ROGBot
08-04-2018 06:47 AM
08-11-2018 10:02 AM
Rob W. wrote:
Hi rishabh.
If your board is booting ok and getting to windows and then hangs, I would double check that you loaded the correct drivers, if they are ok ?
Then try re-installing windows , seems a windows conflict may be going on.
08-04-2018 02:19 PM
08-11-2018 10:04 AM
F0x135 wrote:
I had this happen to me earlier in the year, taking up to 30 mins to boot on a brand new 8700K build.
Turned out one of my old drives was dying. Unplugging that and everything booted in 30 secs. One of your drives could be dying, even the new one might be faulty.
08-11-2018 10:05 AM
08-11-2018 08:04 PM
Rob W. wrote:
I can’t see the case slowing it down, seems most likely a Driver conflict,
Did you remove the drivers before installing the new ones? *Also are you on latest bios?*
08-11-2018 02:08 PM
