Results 1 to 8 of 8
    ROG Junior Member Array
    Jan 2018
    4
    GPU TWEAK II problem
    Having an issue here
    Something's really off-hand, need help asap.
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,373
    Hi RF69
    Maybe try the new version 1.8.3.5 it has OSD too.
    Click the link and scroll down to GPU Tweak II 1.8.3.5.exe (beta)
    https://rog.asus.com/forum/showthrea...esting-Program
    See if this is any better.
    Jan 2018
    4
    Quote Originally Posted by Nate152 View Post
    Hi RF69
    Wellp, nothing's changed.
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,373
    Ok, thank you for trying that, I'm not sure why it would be reading the Boost Clock like that but it is reading correctly in the monitor.
    I see you're in OC Mode, is it any better with the the other Modes or creating a profile? Are you able to move the GPU Boost Clock slider when creating a profile ?
    Jan 2018
    4
    Doesn't change anything actually
    https://youtu.be/o9c9S44Koxo
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,373
    All right thank you for the video, yeah there's definitely something screwy going on.
    I can confirm 1.8.3.5 is working so here is what I would do.
    Uninstall both versions of gpu tweak II, run CCleaner to clean the registry
    Install the latest Nvidia driver 398.82
    Install GPU Tweak II version 1.8.3.5 again
Name:	gpu tweak 2.png
  7. #7
    Jan 2018
    4
    Ok, that's better, but still it tries to be as deviant as possible.
    https://youtu.be/uJFe3qNNJDs
  8. #8
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,373
    All right great and thanks for the video once again, now I'll post you one.
    The OSD is cool, I downloaded the ROG Logo and added the choice of champions. You can add any picture and adjust the size and transparency, the picture can be on 100% of the screen if you wanted it.
Tags for this Thread
