Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 38
  1. #21
    New ROGer Array
    Apr 2019
    2
    Guys do you have GForce Experience installed? I noticed that my laptop out of the sudden became loud, fan like 100% and there was no reaction for turning on silent, balanced or boosted mode. I started looking for a solution and found this thread, Nvidia driver mentioned here gave me a clue. In my case GForce experience downloaded an update which was ready to install but not installed because of this old version wasn't running in my system. When I clicked on the icon to open it, GForce experience started automatic installation and once the program opened up fan instantly went to silent.
    If you look in GForce Experience options there is "Whisper mode - Makes your plugged-in laptop quiet while gaming."
    Try that, maybe it will solve your problem as well.
  2. #22
    New ROGer Array
    Sep 2019
    1
    Post possoble problem
    Hei guys,
    i am gonna share my experience with you regarding this fan problem.
    I had the same problem with my GL504G, for first two weeks laptop worked as it should. But then left fan started going bonkers. It went full throtle most of the time. I tried several driver reinstals and so on, then i came to idea, maybe, just maybe heat sink doesnt transfer heat for some reason and laptop is getting a constant signal that its hot. And eureka, heatsink has a flaw, left side is very thin and after some usage it deforms and dissataches itselft from some components that are connected via thermal paste to it. After reapplying thermal paste and attaching heatsink so it stays attached, laptop has been working perfectly, only going full throtle on overboost mode when playing some demanding games (its now ~3 months since i did that and all is good).
  3. #23
    ROG Member Array
    Oct 2018
    7
    Quote Originally Posted by Folklore dancer View Post
    Hei guys,
    Can you give a little more detail before I take my new laptop apart? Which heat sink? Where is it located?
    My problem is the GPU fan runs full, half, or silent speed completely randomly, even when the system is using the Intel GPU and GPU Tweak reports it's only at 34 degrees C. So I don't want to start randomly pulling off heatsinks
  4. #24
    New ROGer Array
    Oct 2019
    2
    Hei guys,
    Had to make an account to thank you for this post.
    I have been stalking this thread for months, constantly looking for a solution thinking that the issue was related to software/bios/etc. But nothing ever worked, and when I read your post it finally made sense, even though I thought there was no way it could be hardware related.
    I didn't even need to reapply the thermal paste, I just moved the CPU fan cable around a bit and tightened the heatsink screws, and the fans stopped going crazy permanently since then.
    So if anyone else is having the issue where the CPU fan goes crazy loud on maximum speed and nothing can stop it, your issue is hardware related, not software. Either open up your laptop and tighten/remount/repaste the heatsink or go to a technician to help you with that if you can't do it, but it's pretty easy to be honest.
  5. #25
    New ROGer Array
    Jul 2019
    18
    Quote Originally Posted by vz5zF0 View Post
    If the problem is solved, congratulations!
    *** You just tightened the screw that the radiator is pressing on the CPU cover,right?. What do you mean by "moved the CPU fan cable around a bit", is it pulling the plug down, or you just touch it.
    *** I noticed that unplugging the fan plug and plugging it back can solve the fan problem for a few days to a few weeks. I don't know if you solved the problem in this way.
    I really hope someone can help me. I have tried many methods, but I have not completely solved my problem.
    Thank you very much!
  6. #26
    ROG Member Array
    May 2018
    22
    I just bought the whole "fan+radiator" hardware from asus-accessories.com site. It wasn't delivered yet, so I cannot say if replacing it solves the problem... I just hope so, otherwise, I see no other option than buy another notebook from another brand.
  7. #27
    New ROGer Array
    Oct 2019
    2
    Quote Originally Posted by 棽œ View Post
    Yeah I tightened all the screws related to the CPU part of the heatsink, and wiggled (didn't unplug) the CPU fan wire around a bit and noticed that it kept slowing down the fan speed from maximum when I did that. Eventually it stopped doing it completely, not sure what fixed it exactly, but I hope it's not temporary like you said with unplugging and replugging the cable. It's been around 1-2 weeks now with no issues. If it starts doing it again I'll unscrew the whole heatsink and repaste everything and see if it helps, but it hasn't come back yet.
  8. #28
    New ROGer Array
    Jul 2019
    18
    So, was the computer on when you wiggled the CPU fan wire and tighten the screws? My computer is notebook gl540gm and i think doing this things while computer is on is not safe. But If you really did this, I will try. At least this will solve the problem.
    thank you.
  9. #29
    ROG Member Array
    Jan 2019
    Hi there.
    My GL504 started doing the same, but it actually dies down after a little bit (10 minutes) from power on. I have always read about the left vent, but my problem is actually related to the right one (under the power on button). Is it the same issue? Moreover, if i open the back cover to touch fans and screws, doesn't it invalidate the warranty ?
  10. #30
    New ROGer Array PowerPein PC Specs
    PowerPein PC Specs
    Laptop (Model)GL504GS
    MotherboardASUS Rog Scar II
    Processori7-8750H
    Memory (part number)Kingstone hyperx 2X16 GB
    Graphics Card #1Geforce GTX 1070
    Sound CardRealtek/ USB Roccet Juke
    Monitor1080P 144 Hz
    Storage #1Toshiba SSD PCIe
    Storage #2Toshiba SATA III 2 TB
    Power Supplyoriginal
    Keyboard USB ASUS strix tactic pro
    Mouse TRUST gaming mouse
    Headset Sonic G910 7.1 vibration
    Headset/Speakers Genius GX 3000 2.1
    OS Win 10 Enterpise
    Network RouterASUS RT AC 1200 G
    PowerPein's Avatar
    Jan 2020
    21
    Quote Originally Posted by dan_himura View Post
    Hi there.
    The warranty will be voided if a sticker on one of the screws on the system board is damaged. I had this sticker on the screw on the SSD. Of course, the fan connector is below the SSD.
    I already put the Teflon tape on the connector to prevent it from accidentally moving. I have now succeeded in solving the problem that the fan does high spin: liquid metal heat conductor (GPU, CPU), new video card fan (the old one had a coffee grinder sound after half a year), the latest Intel Dynamic Platform and Thermal Framework Drive (DPTF_Intel_CFL_W10_64_V84105016067). I don't know why, but half a year ago the win8 driver was still available for win10. The file you download in its name contains the win version (W10 or W8.1). It is hidden under "other" in the download center.
    Win10 Enterprise is installed on the machine (I had problems with Pro after 1.5 years). It is still running (4 days ago) and it will turn out how long. The fan shows a quarter-year-old dust, which I only brushed with a toothbrush and then blown it out with compressed air.
    If you have already disassembled the machine, be sure to look at this cable. The monitor cable for me was pinched to connect the power circuit.
