Results 1 to 10 of 11
08-11-2018 10:18 AM #1
amalkumar PC Specs Motherboard ROG CROSSHAIR VI HERO Processor Ryzen 1700 3.9Ghz Memory (part number) CMK32GX4M2B3000C15 Graphics Card #1 GTX 1070 Monitor Acer Storage #1 Samsung SSD Storage #2 Segate CPU Cooler Hydro Series™ H115i 280mm Extreme Performance Liquid CPU Cooler Case Cosair 750D Power Supply Cosari RM 750
- Join Date
- Jul 2017
- Reputation
- 10
- Posts
- 51
Ryzen 2700x VS 1700 What is Best And Better??
Ryzen 2700x VS 1700 Better For Video Edting
08-12-2018 12:50 PM #2
Sigtran PC Specs Motherboard Asus Crosshair VI Hero Processor Ryzen 9 3900x Memory (part number) F4-3200C14D-16GVK @ 3600MHz Graphics Card #1 Gigabyte GTX1080ti Gaming OC Monitor 27" Lenovo Legion Y27q-20, WQHD 165Hz IPS Storage #1 Samsung 970 EVO Plus 1TB Storage #2 Samsung 860 EVO 1TB CPU Cooler Noctua NH-D14 Case CoolerMaster 690 Power Supply Corsair HX1000i Keyboard Dell SK-8115 Mouse Logitech G305 Headset/Speakers Logitech X-540 OS Win10 X64 Home Network Router AC2600 Accessory #1 Logitech C930e webcam
- Join Date
- Sep 2017
- Reputation
- 28
- Posts
- 73
Stock, 2700x would be much better, like 25% faster or even more (3.7GHz vs 3.0GHz base clock, when all cores loaded, but also when just few cores loaded difference could be higher due to Precision Boost 2 on 2700x).
Overclocked all cores, assuming 4.2GHz 2700x and 3.9GHz 1700, difference would be a bit less, like 15-20% max.
All this, if bottleneck is on CPU... On other hand, if your RAM capacity is not enough or scratch disk is slow, then using faster CPU would not noticeably improve the situation...
08-14-2018 09:53 AM #3
Rares PC Specs Motherboard CH7 Processor Ryzen 2700x Memory (part number) FlareX 3200 CL14 Graphics Card #1 RX 580
- Join Date
- Feb 2012
- Reputation
- 10
- Posts
- 22
08-16-2018 10:15 AM #4
neikosr0x PC Specs Motherboard x570 Crosshair Dark Hero Processor Ryzen 5900x Memory (part number) G.Skill 4000cl18 @ 3600 cl16 Graphics Card #1 Nvidia RTX 3080 Monitor Samsung G7 Storage #1 Samsung Evo 970 Plus Storage #2 Western Digital SN850 CPU Cooler Corsair H115i RGB Case Phanteks P500A Power Supply Corsair RM1000i Keyboard Corsair K70 Mouse Corsair Headset JBL quantum 800 Mouse Pad Asus ROG OS Windows 10 Pro
- Join Date
- May 2018
- Reputation
- 10
- Posts
- 14
I own both, i have a 1700x on a Gigabyte 370x G5 and a 2700x on a Asus CH 7 Hero.
The difference is a lot, from stability to gaming and rendering.
the 1700x you could get it to 4.0 but hardly stable and you will get lots of heat on the VRM and CPU. At defaults it works just fine you can also do some stable OC to 3.9ghz now. the 2700x at stocks manages to clock almost to its highest you will get around 3.9 to 4.1 at stock settings while gaming or rendering of course the cpu will hit 4.35 as well with no problems, but with the ch7 you can do some tweaks and it will hit 4.35 on single workloads with no problem 100% stable and at low temps and you could also get 4.0 to 4.1 or even more on multi core op. And on Overclocking you are aiming to 4.2 super easy with very decent temps.
08-16-2018 03:27 PM #5
- Join Date
- Jul 2017
- Reputation
- 10
- Posts
- 51
08-16-2018 04:00 PM #6
- Join Date
- Jul 2018
- Reputation
- 10
- Posts
- 13
08-17-2018 01:06 AM #7
- Join Date
- Jul 2017
- Reputation
- 10
- Posts
- 51
08-17-2018 07:12 AM #8
- Join Date
- Jul 2018
- Reputation
- 10
- Posts
- 13
Intel Core i7 8700K is better from any point of view:
1) 5-10% faster in almost any benchmark (you can find dozens of them over the net)
Example: https://www.techspot.com/review/1655...ryzen-7-2700x/
2) includes the Intel UHD Graphics 630 (very good option if you don't have discrete GPU)
3) similar price with Ryzen 2700X
08-17-2018 04:48 PM #9
SIMONHANDLEY1 PC Specs Laptop (Model) Don't be silly Motherboard Asus - CROSSHAIR VIII HERO ATX AM4 Motherboard Processor AMD - Ryzen 7 3700X 4.3GHz 8-Core Processor (OC to 4.366 ghz) Memory (part number) Corsair - Dominator Platinum (4 x 16GB) DDR4-3466 Memory Graphics Card #1 EVGA RTX 2080ti FTW Hybrid Graphics Card #2 Can't afford it! Graphics Card #3 Still can't afford it! Graphics Card #4 What did I just say! Sound Card Eh! Monitor ACER 144Hz 2K Monitor Storage #1 Samsung - 860 Evo 1000GB 2.5" Solid State Drive Storage #2 Samsung - 860 EVO-Series 500GB 2.5" Solid State Drive CPU Cooler NZXT - Kraken X52 Liquid CPU Cooler Case EVGA DG-77 RGB ATX Mid Tower Case Power Supply Corsair HX 1000 80+ Platinum 1000w ATX Power Supply Keyboard Asus Cerberus LED Backlit USB Gaming Keyboard Mouse Asus Cerberus gaming mouse Headset Sennheiser - HD205-II Headphones Mouse Pad Asus Cerberus gaming surface mouse pad Headset/Speakers Speakers, my wife would kill me! OS Windows 10 pro Accessory #1 BraZen Shadow PC Gaming Chair - Black/White
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 108
That's not quite true, you need to purchase a cooler with intel!
08-18-2018 01:00 AM #10
- Join Date
- Jul 2017
- Reputation
- 10
- Posts
- 51
