Results 1 to 3 of 3
    New ROGer Array
    Aug 2018
    1
    Samsung 970Pro M.2 SSD not showed in BIOS (But works!)
    Hey guys,
    I’m new in the forum and will directly bother you with a problem :P
    As the name says I got some troubles with my M.2 SSD. But firstly here my specs:
    Case: Fractal Nano S
    Mainboard: Asus ROG STRIX Z370-I Gaming
    CPU: 8086k (delidded/liquid metal/copper IHS)
    Cooling: Custom Loop
    RAM: 32GB TridentZ 3.200 Mhz
    GPU: EVGA GeForce GTX 1080 Ti SC2 Gaming
    PSU: Silverstone Strider 800W Platinum
    SSD M.2: 512GB Samsung 970 Pro Evo M.2 2280 NVMe
    SSD 2,5": 256GB Intel 545S
    HDD: Seagate Barracuda 4TB 7200 RPM
    OS: Windows 10 Pro
    BIOS VERSION: 1002 (latest)
    For further information: https://pcpartpicker.com/b/wvvnTW
    Before I got the 970 Pro M.2 two days ago I had the 960 M.2. I’ve had the same problem with both:
    I installed the SSD in the M.2_1(SOCKET3) on the front side.
    The SSD was recognized during the installation and also afterwards when the system was set up properly.
    In the BIOS the SSD shows up in the “Boot Briority” (1. Windows Boot Manager Samsung 970 Pro)
    So far everything is fine. But it just bugs me that the SSD is not listed under storages. Not on the main page, EZ mode (M.2 = N/A) neither under Storage configuration (Empty)
    The BIOS is set up properly, AHCI enabled, CMS enabled and Hyper M.2X16 disabled.
    Does anybody has an idea what could cause this problem and how to solve it?
    Finaly, i want to mention that english isn't my nativ language so please apologize if the text contains some grammatically mistakes
    I hope you guys can help me figure it out!
    Best regards,
    ROG Guru: Yellow Belt Array Baio73 PC Specs
    Baio73 PC Specs
    MotherboardAsus ROG Crosshair VIII Formula BIOS 3402
    ProcessorAMD Ryzen 3900XT
    Memory (part number)2x8 Corsair 4000C19D
    Graphics Card #1Sapphire RX 5700XT
    MonitorLG 34GK950F
    Storage #1Samsung 980PRO 512Gb NVMe
    Storage #2WD Black SN850 2Tb NVMe
    CPU CoolerCorsair H150i Elite Capellix
    CaseLian Li 011D XL
    Power SupplyCorsair AX860i
    Keyboard Logitech G513
    Mouse Logitech G903 + Powerplay
    Headset G933 Artemis Spectrum
    Mouse Pad Corsair MM 700 RGB
    Headset/Speakers Logitech G560
    OS Windows 10 64bit
    Network RouterLynksys EA6500
    Accessory #1 Corsair Commander Pro
    Accessory #2 10xCorsair QL120 RGB fan
    Jul 2014
    11
    157
    Same issue here with 960Pro 512Gb and Hero VII WiFi… disappeared from the "SATA" tab (BIOS shows only the empty secondary M.2 slot), present in "Boot" tab and working.
    In my system it disappeared after flashing the latest BIOS.
    Someone told me it's a matter of Windows 10 UEFI installation, but I installed the SO in leagcy mode.
    Baio
    Baio73 PC Specs
    MonitorLG 34GK950F
    CaseLian Li 011D XL
    OS Windows 10 64bit
    Jul 2014
    11
    157
Tags for this Thread
