Results 1 to 3 of 3
Thread: Fan advice
    ROG Member Array
    Aug 2018
    11
    16
    Fan advice
    I've got a Coolermaster H500P case with 2 front fans and 1 back fan and a H115i cooler in my Maximus X Hero. I've had it set up for almost a week playing and tweaking with it. It runs just fine but I can't leave good enough alone.
    I have the front and back fans on a splitter running together and Qfan turned off. I'm not curious if have the fans together is a dumb move. Its silent AF but I wonder if this is not the best setup for me. Should I have each fan on it's on? This MB has enough fan headers so what's the consensus of the geniuses on this great forum?
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,119
    as long as the fan power output is under 1A total you are all good.
    ROG Enthusiast Array offthewall69 PC Specs
    Laptop (Model)Alienware 15R3 (for eh, work)
    MotherboardMaximus IX Hero
    ProcessorI7 7700K underwater
    Memory (part number)G.SKILL DDR4 3200, F4-3200C16Q-32GTZR
    Graphics Card #1EVGA GTX 1080 FTW Hydro Copper 08G-P4-6299-KR underwater
    Graphics Card #2EVGA GTX 1080 FTW Hydro Copper 08G-P4-6299-KR underwater
    MonitorAOC Agon AG352UCG 35” Curved G-Sync
    Storage #1SAMSUNG 850 EVO 2.5" 1TB SSD
    Storage #2SAMSUNG 850 EVO 2.5" 500GB SSD
    CPU CoolerCPU & GPU in an open loop with EKWB blocks and pump and alphacool 120 and 360 x-flow radiators
    CaseIn Win 305 Black
    Power SupplyEVGA SuperNOVA 1000 G3
    Keyboard Razer Blackwidow
    Mouse Razer DeathAdder
    Headset HyperX Cloud II Gaming Headset
    OS Windows 10 Pro
    Accessory #1 Razer Tartarus Keypad
    Accessory #2 EK-FB ASUS M9H Monoblock - Nickel
    offthewall69's Avatar
    Apr 2015
    35
    Are they PWM (4 pin) or DC (three pin)? If all three fans are identical, it's not much of an issue. For PWM fans they take the tach reading from one fan and send the PWM signal equally to all on the splitter. I personally would have them broken up by location (front, back, and AIO [or CPU/Alt] for the cooler. then you can adjust as necessary to achieve optimum pressure differential. But it's really just for playing around with the fan curve in FanXpert. Sounds nice to hear the fans start cranking up when doing benchmarks, etc...
