Results 1 to 9 of 9
    ROG Guru: Yellow Belt Array Moises2018's Avatar
    Dec 2012
    130
    Can I add another 16GB Memory Kit? Please say it's possible!!!
    Hello,
    I currently have 16 GB (2 X 8GB) of DDR4 3200 memory. I want to upgrade the system memory to 32GB. However, an ASUS tech mentioned to me that I would most likely have stability/performance problems if I upgraded my system memory. He mentioned that I should have purchased a 32GB kit to begin with.
    I have the G.Skill TridentZ RGB Series 16GB (2 X 8GB) Kit. Model: F4-3200C14D-16GTZR.
    I want to purchase the same exact kit, same model in order to have 32GB of system memory; but is it true that I will have possible stability/performance issues if I add another 16GB memory kit?
    Is there problems with adding two 16GB memory kits (same model) instead of a 32GB kit?
    Can someone please shed some light on the matter?
    Thank you!
    System specifications:
    Motherboard: Maximus X Hero
    BIOS Version
    : 1401
    OS: WIN 10 64 Bit
    CPU: i7-8700K @3.7GHz
    CPU Cooler: Corsair H100i Water Cooler
    Memory:
    G.SKILL TridentZ RGB Series 16GB (2 x 8GB) DDR4 3200 (PC4 25600)
    Video Card: Gigabyte GeForce GTX 1080TI
    SSD: Samsung 970 PRO M.2 (2280) 512GB &
    Intel 335 Series 240GB (secondary drive)
    Power Supply: Cooler Master Silent Pro 1000W
    Hard Drives: WD 700GB & WD 300GB SATA
    Optical Drives: 1 Asus Blu-Ray Drive & 1 DVD/RW Drive
    ROG Guru: Orange Belt Array Rob W. PC Specs
    Rob W. PC Specs
    MotherboardRog Asus Rampage vi extreme
    ProcessorIntel i9-7980x Oc 4.6ghz 24/7
    Memory (part number)64 gb GSkill 3600mhz (8x8) 15,15,15,35
    Graphics Card #1nvidia Titan V + ekwb custom loop
    Graphics Card #2nvidia RTX 2080Ti on air.
    Sound Cardonboard?
    MonitorIAsus PA329Q 4k 32"
    Storage #1samsung SSD 960 EVO 250 GB. M2 nvme
    Storage #2Samsung ssd 970 evo 500gb m2 nvme
    CPU CoolerEKwb custom loop
    CaseCorsair Obsidian 900
    Power SupplyCorsair HX1200i 1200w
    Keyboard Logitech G910 orion spark
    Mouse Logitech G502 Proteus core
    OS Win 10
    Network Routerbt infinity super fast.
    Accessory #1 Seagate Barracuda 2 TB HDD
    Accessory #2 Aqeuaro 6xt fan controller
    Accessory #3 Intel Optane 280gb
    Dec 2015
    104
    487
    Hi Moises2018,
    Yes they are quite right it can cause stability issues.
    A kit is produced from matching ram modules ie; they have the same response at the same power input and the same speed and given a sequential number,
    So although you can get 2 identical kits, they will be running at different speeds and would therefore cause instability!
    It is possible to alter the timings and voltages to ease this and enable the two kits to work together but not garunteed.
    I personally did the same and brought two kits for my other rig and two years later they still won’t work together, even though they will work on the same settings individually.
    I could have put that a bit more technically but that’s how I see it.
    Could sell the kit you have to help fund a larger kit, or, try tinkerring with the timings, there are plenty here that could guide you in the right direction, but no garuntees it will work.*
    ROG Guru: Yellow Belt Array Mr. Fox PC Specs
    Mr. Fox PC Specs
    Laptop (Model)- NA -
    MotherboardEVGA X299 Dark
    Processori9-7960X @ 5.2GHz
    Memory (part number)32GB Corsair LPX DDR4-4000 @ 4200
    Graphics Card #1EVGA RTX 2080 Ti xC2 Ultra Gaming
    MonitorPredator XB271HU 2560x1440 165Hz
    Storage #1512GB 960 Pro x 2 (OS Boot Drives)
    Storage #2960GB Samung Enterprise NVMe SSD x 2 | 2TB HDD
    CPU CoolerDual 360MM XPSC Rads+1/2 HP Water Chiller
    CasePraxis WetBench
    Power SupplyEVGA SuperNOVA P2 1600W
    Keyboard Corsair K95 RGB
    Mouse SteelSeries Sensei Wireless
    Headset Skullcandy Crusher Wireless S6CRW
    Mouse Pad Black Anodized Aluminum
    Headset/Speakers Logitech Z506 5.1 Speaker System
    OS W10 Ent LTSB 2016 / W7 Ultimate (Dual Boot)
    Accessory #1 Hailea HC-500A 1/2HP~790Watt Water Chiller
    Mr. Fox's Avatar
    May 2018
    41
    126
    You could have stability issues using 4 sticks with the newer Intel ME firmware introduced in BIOS versions 1401 and 1602. I have a 4x8GB kit of Corsair Vengeance LPX DDR4-4000 that worked flawlessly for months, up until the ME version was updated, and now my system is a horrible mess with all 4 sticks installed. Still works flawlessly with only two installed, but all hell breaks loose with 4 sticks installed.
    Flashing the older BIOS 1101 with ME 11.8.50.3425 and previous BIOS versions does not downgrade the ME firmware. Using ASUS BIOS Flashback does not downgrade the ME firmware. So, be prepared to discover the possibility of your system not working right. You may end up sending the memory back for a refund. Don't blame the RAM though. I have an active support ticket with ASUS trying to get them to correct the problem. I cannot get the Intel ME tool to work as the ME region seems to be locked, so I need their help downgrading the ME.
    Punisher | EVGA X299 Dark | i9-7960X @ 5.2GHz | 32GB Corsair LPX 4000 @ 4200 | EVGA 2080 TI xC2 HydroCopper Block
    EVGA SuperNOVA 1600W P2 | 2x 512GB 960 Pro / 2x 1TB Enterprise NVMe / 2TB HDD / 4TB HDD | W10 / W7 (Dual Boot)
    2x XSPC RX360 | Praxis WetBench | Hailea HC-500A (1/2HP~790W) Water Chiller | Results:
    http://hwbot.org/user/mr._fox/
    ROG Guru: Green Belt Array Phillyflyer's Avatar
    Mar 2012
    30
    536
    Quote Originally Posted by Moises2018 View Post
    Hello,
    Thank you!
    It is not recommended to mix ram modules...even same models...not saying you can't....may have to play with alot of the timings to get them to work .....you do however risk the chance of stability when doing so.
    Asus ROG Maximus XI EXTREME
    Intel i7 9900K OC'D @ 5.2 GHZ @ 1.345V (1.296V LOAD) LLC 6 PRIME 95 STABLE 8 HRS
    XSPC RX360 Rad (6)Scythe Gentle Typhoon 1850 RPM Fans In Push/Pull @ 1500 RPMS
    Swiftech Drive II / Swiftech MCP35X Pump
    Enermax Platimax 1200 Watt Power Supply
    32GB G.Skill F4-3866C18Q-32GTZR 3866 MHZ CL18 1.35V (OC 4266MHZ 17-18-18-41-2T @1.45V)
    MSI GTX 1070 SEA HAWK EK X SLI WITH ASUS HB RGB
    (5)Samsung 840 Pro 128 GB In Raid 0
    (2) WD 1TB Black Edition
    Corsair 900 D
    Mr. Fox PC Specs
    CasePraxis WetBench
    Mr. Fox's Avatar
    May 2018
    41
    126
    If the SPD is not identical you could have stability issuses. If the modules are identical (hardware) in every respect you can use Thaiphoon Burner to transfer the firmware. Doing this could void the warranty on the memory. It would be best to sell your 2 sticks kit and buy the 4-stick kit. Some of the 4-stick kits have the SPD configured for 1 DIMM per channel and they are intended for quad-channel systems, not dual-channel with 2 DIMM per channel.
    ROG Member Array Threat PC Specs
    Threat PC Specs
    MotherboardAsus ROG MAXIMUS X HERO (WI-FI AC)
    ProcessorIntel Core i7-8700K
    Memory (part number)G.Skill Trident Z 16GB (2 x 8GB) DDR4-3600
    Graphics Card #1MSI GeForce GTX 1080 Ti 11GB GAMING X
    MonitorAsus VG248QE 24.0" 144Hz LED Gaming Monitor
    Storage #1Samsung 970 EVO 250GB NVMe PCIe M.2 2280
    Storage #2Seagate 2TB Internal Hybrid Drive
    CPU CoolerNZXT Kraken X62 Rev 2 98.2 CFM Liquid CPU Cooler
    CaseFractal Design Define R6 Blackout TG ATX Mid Tower Case
    Power SupplyEVGA SuperNOVA G2 850W 80+ Gold
    Keyboard Azio Mk Hue Black USB Backlit Mechanical Keyboard
    Mouse Logitech MX518 Gaming Mouse
    Headset Numark Red Wave Professional Mixing Headphones
    Mouse Pad Reflex Lab Pro 36 Gaming Mouse Pad (36"x12")
    Headset/Speakers Logitech Z313 Speaker System
    OS Windows 7 Home Professional (lol)
    Accessory #1 Scarlett 2i2 Audio Interface
    Accessory #2 Wacom Cintiq 13HD
    Accessory #3 Asus VE248H 24.0" LED Monitor
    Threat's Avatar
    Jun 2018
    13
    Quote Originally Posted by Phillyflyer View Post
    Isn't there also a specific type of memory or brand (g. skill?) that showed to have issues with the Maximux X Hero wifi? I tried to search, but couldn't find an exact answer. I thought I recall you knowing what it was?
  7. #7
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    I would never say you could safely do this and you have to understand that if you purchase a second kit it is all on you
    But if your kit is the 3200 14-14-14-34 kit I would say you have a good chance of them working together, I say this because I have owned several of the 4x8GB kits of that speed and have used 2 3600 15-15-15 kits together without issue.
    You would be better to sell the 2x8 kit and purchase the 4x8 kit of the same speed and timings, or purchase from a store with a return policy in case it is not successful
  8. #8
    Mar 2012
    30
    536
    Quote Originally Posted by Threat View Post
    The GSkill kit you are probably referring to is the 3600 mhz CL15 kit which seems to be giving people issues with the Hero or Formula...not quite sure which board...maybe both....if memory serves me correct....I know that at one time I had tried the GSkill Trident Z RGB 3600mhz CL 16 kit (2 dual kits with sequential serial numbers) on the Asus V10 x99 board and had no issues whatsoever....Fact remains...it's best to buy 1 quad kit vs 2 dual kits and save yourself the very possibility of running into issues when mixing kits.
    Corsair 900 D
  9. #9
    Dec 2012
    130
    WOW, I can't believe it! Makes me so sad & upset that's the case, that two same model kits (2X8) will possibly have performance/stability issues unless it's a 4X8GB kit... Gosh, why do PC's have to be so darn stressful and difficult, besides all the money you drop into the hobby!
    I appreciate everyone that has helped and contributed! THANK YOU!
    BIOS Version
    : 1401
    OS: WIN 10 64 Bit
    Memory:
