Results 1 to 10 of 23
08-17-2018 12:29 AM #1
- Join Date
- Aug 2018
- Reputation
- 10
- Posts
- 51
Maximus X Hero (Wifi) - 40mm Fan Bracket - Meant to be Bent?
The 40mm fan bracket that came with my X Hero seems to be bent in two parts - please see the pics. I can't quite tell if it's meant to be bent like this so the fan sits at a slightly jaunty angle, or if it's just got bent during packaging or shipping. It appears pretty easy to bend back to right angles at all the joins if I wanted to, but I don't want to do that if it's meant to be a little off. EDIT: Not sure why the post rotated my pics 90degrees: here's the imgur link for horizontal https://imgur.com/a/uWgDDdo
Many thanks!
08-17-2018 12:44 AM #2
- Join Date
- Jun 2018
- Reputation
- 10
- Posts
- 79
My name is Adrian from the ASUS Customer Loyalty Team here at our North America Corporate Office. If you would allow, it would be more than glad to help provide resolution to this case. I've verified your part with ours, and yours is just about less than 5° off. You can indeed bend it to your style, but just don't abruptly bend it. If any issues arise with the functionality of your motherboard, you can contact me at cl-adrian@asus.com.
Thank you for choosing ASUS!
Best Regards,
Adrian
ASUS Customer Loyalty – US Support
08-17-2018 01:06 AM #3
- Join Date
- Aug 2018
- Reputation
- 10
- Posts
- 51
Hi Adrian
Thanks for the quick response. I'm also a little confused as to which mounting hole you're meant to use for this bracket - as the instruction manual and the packaging for the bracket show different holes to be used. Further, if you used the hole shown in the instruction manual the fan would just be blowing straight onto the top of the I/O shield, which is not the part it's supposed to be cooling (the VRMs). Would you mind please checking in and letting me know which mounting hole this fan bracket is supposed to be mounted on? Many thanks again!
08-17-2018 08:01 AM #4
Carlyle2020 PC Specs Motherboard Asus Maximus XI APEX Processor gaming9900ks@5.2/avx 0/ adaptive vcore / 1.35+0.020 offs/LLC5/ac ll 0.01/TVB off/power saving on Memory (part number) Gskill 4400 CL16 /65k r /65k w / 60k c Graphics Card #1 3080 ftw ultra /pads on backplate Sound Card Xonar STXII mods:3xLME 49720NA Monitor LG 38GL950G / -HDR / +madVR Storage #1 2TB 970evo plus nvme Storage #2 1TB 960evo nvme +2x 1tb evo 860 hw-sata-raid CPU Cooler arctic freezer II 280 Case Unique Silverstone FT2 dampened up the wazoo V2.0 Power Supply Seasonic TX-850 Keyboard Cherry KC 1000 on top of a cherry MX1 for ergonomics :) Mouse MX Master 3 Headset Sennheiser PC360 + Philips X2HR Headset/Speakers A250 / cause LG was stingy OS Win 10 64bit Network Router yeah right... Accessory #1 Silverstone EBA01 headphone stand / black Accessory #2 radio Keyfob to turn on and off Accessory #3 4 bay fantec /10tb red/+scrap
- Join Date
- Mar 2018
- Reputation
- 17
- Posts
- 154
08-17-2018 05:04 PM #5
- Join Date
- Aug 2018
- Reputation
- 10
- Posts
- 51
08-18-2018 12:29 AM #6
- Join Date
- Jun 2018
- Reputation
- 10
- Posts
- 79
Hi mrvortep,
No worries, the marketed use for the bracket is to cool the VRMs, but from i've seen online others have used it to cool M.2 drives as well, or create better airflow behind the motherboard where you mount your CPU. You also can bend the bracket to give a certain spot more air flow but that's all preferences, but the purpose is to generate better airflow towards the top right of the motherboard where heat tends to build up, as the VRMs should be located both on top and to the left of the CPU.
Best Regards,
Adrian
08-18-2018 05:59 AM #7
- Join Date
- Aug 2018
- Reputation
- 10
- Posts
- 51
Thanks Adrian but I'm still a little confused. If I want to use the bracket/fan to cool the VRMs, which mounting hole should I use in the Maximus X Hero?
1. The mounting hole at the top-left corner of the motherboard, right in the corner next to the I/O shield; OR
2. The mounting hole at the top edge, just right of center above and slightly left of the DIMMs?
Thanks!Last edited by mrvortep; 08-18-2018 at 06:05 AM.
08-21-2018 12:20 AM #8
- Join Date
- Jun 2018
- Reputation
- 10
- Posts
- 79
08-21-2018 12:27 PM #9
- Join Date
- Aug 2018
- Reputation
- 10
- Posts
- 51
08-22-2018 07:52 PM #10
- Join Date
- Jun 2018
- Reputation
- 10
- Posts
- 79
