Results 1 to 3 of 3
    ROG Enthusiast Array
    Jun 2018
    11
    64
    Do I need these Asus services running?
    I tried AISuite at one stage but ultimately ended up un-installing it.
    Just doing some spring cleaning on my PC and come across some ASUS services in msconfig startup services they are:
    ASUS Com Service
    Asus System Control Service
    ASIS Update service (Asus)
    AsusFanControlService
    Asus Update Service (AsusM)
    I have done some googling but been left a little confused, are any of these solely related to AIsuite? So I can safely uncheck them from the startup list.
    Also, are they important, and which ones do need to be running?
    ROG Guru: Orange Belt Array chevell65 PC Specs
    chevell65 PC Specs
    MotherboardROG Strix Z370-H, ROG Maximus VII Z97
    ProcessorIntel 4790K 4.6GHz, Intel i5 8400, Intel e8600 Wolfdale, Intel Q9650 Yorkfield, Intel E6750 Conroe
    Memory (part number)16GB G.Skill PC3600
    Graphics Card #1GTX 660 OC
    MonitorAsus 23"
    CaseCorsair clear case
    Power SupplyThermaltake
    Keyboard Logitech G15
    Mouse Logitech G9
    OS Windows 10 Pro
    Network RouterDLink DIR-655, Asus AC88
    chevell65's Avatar
    Oct 2014
    56
    367
    Those are just left over from AI suite. The uninstall tool doesn't remove them but you can disable them from starting in services.
    Jun 2018
    11
    64
    Quote Originally Posted by chevell65 View Post
    Thank you for your swift response.
    So just to confirm all 5 of those I can safely disable?
    I have another asus service called lighting service, but I guess that was for the RGB, which I use
