Results 1 to 5 of 5
    ROG Guru: White Belt Array Ghozer PC Specs
    Ghozer PC Specs
    MotherboardAsus Prime Z270-A
    Processori7-7700k
    Memory (part number)16GB G.Skill TridentZ RGB DDR4-3200
    Graphics Card #1Asus ROG Strix GTX 1070
    Monitor2x HP 23xi
    Storage #1Samsung 970 Pro 512GB
    Storage #22TB Seagate Firecuda SSHD
    CPU CoolerAntec 120mm AIO
    CasePhanteks P400S
    Power SupplyCorsair RM750X
    Keyboard Asus ROG Strix Flare
    Mouse Asus ROG Gladius II
    Headset Steel Series Arctis 5 RGB
    Mouse Pad Random Alienware
    Headset/Speakers Creative Inspire GD580
    OS Windows 10
    Network RouterISP Standard (350mb/35mb)
    Jun 2017
    92
    [Aura] - Many Issues - has development stopped?
    It seems that development of Asus Aura has stopped, along with Armoury...
    I have had my system a year and 1/2 now, and since day 1 Aura has been buggy, forgets settings, randomly detects (or doesn't) my RAM, changes the colour profile/settings I have set each time it re-detects the RAM...
    It's slow, buggy, crashes often (especially if you try to open it within a few seconds of the PC starting up)
    Limited options (should be able to select effect on a PER ZONE basis for one thing)
    it forgets how I have set things, resetting to "single colour" instead of "by areas"....
    Also, when my RAM is detected, if I set DRAM1_1 as a colour, BOTH modules change at the same time to the same thing, instead of individually...
    It also likes to mess with my mouse, if I have a profile set via Amoury, then sync my mouse in Aura, then remove the mouse from the Selection in Aura, I need to open Armoury again for it to re-set my mouse lighting to how I had it... even then it doesn't always work properly due to UI issues in Armoury (which I reported over a year ago and is still not fixed)
    ROG Guru: Yellow Belt Array F0x135 PC Specs
    F0x135 PC Specs
    MotherboardROG Strix Z370-F
    Processor8700K
    Memory (part number)F4-2400C15Q-32GTZR
    Graphics Card #1Gigabyte Gaming 3090 OC
    MonitorAgon AG352UCG
    Storage #1Samsung 970 Evo NVME 500GB
    Storage #2Samsung 860 Evo 1TB
    CPU CoolerCoolermaster ML240R aRGB
    CaseLian Li Lancool 2 Mesh
    Power SupplySeasonic GOLD 750W
    Keyboard ROG Claymore
    Mouse Logitech MX Master
    Oct 2017
    145
    Armoury has had a couple of updates these last few months, one couple of weeks ago. Aura however...
    Ghozer PC Specs
    Processori7-7700k
    Monitor2x HP 23xi
    CasePhanteks P400S
    OS Windows 10
    Jun 2017
    92
    Quote Originally Posted by F0x135 View Post
    That may be, but the issue I reported with Armoury is still present in the latest version....
    Ghozer PC Specs
    Processori7-7700k
    Monitor2x HP 23xi
    CasePhanteks P400S
    OS Windows 10
    Jun 2017
    92
    Just restarted, my RAM is de-synched again, "Header" is now colour cycling (had it static)
    and now when I try and open Aura - it crashes.... won't open, just says "not responding" and quits, don't even get the main screen/window
    F0x135 PC Specs
    Processor8700K
    Oct 2017
    145
    Quote Originally Posted by Ghozer View Post
    Report it in the Armoury thread. MasterC@Asus monitors that thread and most likely won't see this one. I've reported bugs there before and they've fixed it in the next version.
