manual for gt51ch
jordo2k1
Is there any manual for the gt51ch motherboard with all specs and supported ram and ssd etc etc?
im asking as ive recently had a problem with the ssd in the system so i removed it and installed it into the second m.2 slot in the gt51ch and the drive doesnt show up in bios and wont boot.
oddly when i check the bios to enable the port there is no option for the 2nd m.2 socket only an enable /disable for the primary m.2 socket.
is this second port disabled etc etc as i want to upgrade the ssd and would like two m.2 cards.
the board seems bare minimum and i want the manual and specs to check what i can and cant add onto it.
thanks
toronto699
No Manual , Unless Asus Gives You One ,
