08-24-2018 12:40 AM - last edited 3 weeks ago by ROGBot
08-24-2018 06:18 AM
08-28-2018 12:36 AM
08-28-2018 05:34 AM
08-28-2018 08:46 AM
08-29-2018 03:31 PM
Thor3 wrote:
Hi
Have you tried CL14, because i have a kit of Corsair Vengeance lpx 3466 CL16 that i am running 3533 CL14 1.48 V.
I got the timings from Ryzen Dram calculator. 🙂
08-29-2018 03:28 PM
elbubi141180 wrote:
Nice then!
3600 CL16 at 1.4v is a really nice achievement! What CL's your memories are factory rated?
Cheers!
08-29-2018 06:07 AM
DJ Asthma wrote:
Hey hey,
I noticed that there were no post relating detailing if this was succesfull or not to this before i bought the kit, so i decided to share some info on this. I picked up the Corsair Vengeance RGB Pro (2 x 8GB) 3600Mhz kit for my R7 2700x sitting in my C7H running bios 0804. Using the XMP profile, the kit would fail to post (it did so once, but was not repeatable).
I loaded the 3600 Mhz 1.4v profile (Looks like a tuned CL16 preset) found in the bios which was stable. It posts, and have not have a crash, even under stress tests like Prime 95's blend test. I have tested it in Arma3 aswell and all seems good.
I shall keep all of you posted on what happens on this journey, and when i attempt to tighten the timings
