Results 1 to 1 of 1
    ROG Member Array
    Aug 2018
    5
    Cheap LED light kit compatible with Aura Sync
    Hello everyone, I wanted to ask you, if you anyone knows a kit of LED lights cheap to put inside the PC (I do not care high quality lights), € 15 maximum or near, which is synchronized with aura sync, and that it's ready to use it (I'm not very good at doing operations with wires).
    I've looked on the internet, but I've always found them either too expensive, or cheap but not compatible with AURA Sync, I ask you maybe you know someone.
    Thank you so much in advance.
Tags for this Thread
