Results 1 to 4 of 4
    New ROGer Array
    Aug 2018
    1
    Advice/help with ROG Strix X470-F and DDR4 3600
    Working on a new computer build (last build was done over 10 years ago) where I am using a Asus ROG Strix X470-F for the motherboard and G.Skill TridentZ RGB DDR4 3600 for the memory. Before purchasing the mobo I had misread the specs of it and thought it said that it could handle 3600 memory by default so I was confused after get everything put together and powered on to find that the mobo was auto detecting the memory at 2133 instead of 3600. After re-reading the specs I now see that it says 3600o.c. (see below screen shot) which I am taking as it will handle the 3600 if I over clock the system? In the mobo bios under AI Tweaker tab there is an option to change the memory speed from automatic to a number of different options. If I change the speed to 3600 is this considering over clocking and will it break anything? Any help you can provide is greatly appreciated.
Name:	ROG specs.jpg
    New ROGer Array Amos0831 PC Specs
    Amos0831 PC Specs
    MotherboardAsus ROG STRIX X470-F Gaming
    ProcessorAMD 2700X
    Memory (part number)HyperX Predator DDR4 (32GB)
    Graphics Card #1Asus ROG STRIX RX580 T8G Gaming
    Sound CardSupremeFX 8-Channel High Definition Audio CODEC S1220A
    MonitorLG 27UK850-W
    Storage #1Crucial CT500MX500SSD1
    Storage #2Kingston HyperX SH103S3120G
    CPU CoolerAMD Wraith Prism (stock)
    CaseFractal Design Define R6 Black Tempered Glass
    Power SupplyCorsair HX850i
    Keyboard Razer DeathStalker Chroma
    Mouse Razer Naga Chroma
    Mouse Pad Razer Goliathus Control
    Headset/Speakers Microlab Solo 9C
    OS Windows 10 Pro (64-bit)
    Network RouterAsus RT-AC52U
    Amos0831's Avatar
    Oct 2018
    6
    Quote Originally Posted by J The DIYer View Post
Name:	ROG specs.jpg
    Dear J The DIYer,
    I think what you are looking for is the safest way to squeeze out the maximum speed of your high speed RAM modules without harm of your computer. As you wrote you were looking around the AiTweaker menu and sub menus in your MB BIOS and you've found the speed setting options. I recommend you to leave those settings and just boost your RAM's speed with one click by using the D.O.C.P. option under Ai Overclock Tuner sub-menu. This is the first option in the roll down menu and this will set your RAMs speed automatically on the safest way. Since the necessary overclocking information was burned into your RAM by the manufacturer and your RAM modules handles the whole tuning setting process you'll get the required 3600Mhz maximum speed and the optimal voltage settings as well. On this way you don't need to worry about system malfunction or lagging as these tuning settings are tested and supported by the RAM manufacturer and this kind of use will not break the restrictions of guarantee either.
    I hope I could help to you!
    Dec 2011
    354
    25,742
    Short answer is OC to your hearts content.
    The memory profile in either the BIOS or if you prefer set the parameters manually. My advice use the profiles.
    Post up how it goes my friend.
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    499
    13,578
    Technically yes but you won't really break anything. Most likely is the system wont post if the CPU can't handle the high frequency.
    If the RAM is unstable you might corrupt the OS...so maybe backup stuff you don't want to lose before the experiments.
    What is the exact kit that you have?
    3600 is at the top end of what the new AMD CPUs can manage...and might need extra voltage.
    On the extreme tweaker tab in BIOS have a look at Ai overclock Tuner and see what DOCP profiles the RAM comes with...there may be more than one...
    Try 3200 if there is a profile for that...
Tags for this Thread
