Results 1 to 6 of 6
    ROG Member Array
    Aug 2018
    9
    Air Cooling 7980XE on Rampage VI Extreme
    Greetings Peps,
    Before I start please forgive me I'm just getting back to my passion of building my PCs again and loving every minute of it. It has been a while and all these new components everywhere gets confusing sometimes, so thank you all in advance.
    So let start so before I start my build I like to test the mobo before assembly out side the case and would like to use just a simple heatsink/fan config to do so. What have you guys used and what would you recommend.
    ROG Guru: Orange Belt Array restsugavan PC Specs
    MotherboardRAMPAGE VI EXTREME
    ProcessorCore i9 7980XE
    Memory (part number)64GB GSKILL TRIDENT-Z RGB 3200
    Graphics Card #1ASUS ROG POSEIDON
    MonitorSAMSUNG UD590D
    Storage #1INTEL600P 1TB
    CPU CoolerNZXT KRAKEN 62
    CaseCorsair Carbine 540
    Power SupplyCorsair AX1200i
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Headset/Speakers Sony
    OS Windows 10 2019 Insider Preview 18323
    Network RouterD-LINK
    restsugavan's Avatar
    Sep 2017
    36
    373
    Air Cooling was OK if you didn't seriously overclock your rigs, however water cooling price and air cooling price are little bit difference.
    If you want some kind of water cooling unit for basic used I recommend NZXT Kraken X62. See details here. https://www.nzxt.com/products/kraken-x62
    ROG Guru: Orange Belt Array Abaidor PC Specs
    Abaidor PC Specs
    MotherboardRampage VI Extreme
    Processori9-7940X
    Memory (part number)F4-3600C17Q-64GTZR | Trident Z RGB 64GB
    Graphics Card #1Asus Strix 1080Ti OC
    Storage #1Samsung 960 Pro 512GB
    Storage #2WD 10TB Gold
    CPU CoolerEK Rampage VI Monoblock
    CaseC0smos 2 Modded
    Power SupplyCorsair AX1500i
    Abaidor's Avatar
    Dec 2017
    12
    259
    For testing and if you like to have a good Aircooler around I would get the BeQuiet DarkPro 3. I actually intend to get it for such purposes and for backup just in case I need to disconnect my watercooling setup for maintenance.
    ROG Guru: Yellow Belt Array G75rog PC Specs
    G75rog PC Specs
    MotherboardR VI Apex
    ProcessorI9-7900X
    Memory (part number)64GB Gskill Trident Z
    Graphics Card #1AMD Radeon VII EKWB water block
    Graphics Card #2Waste of PCI lanes in NVME environment
    Sound CardStock
    MonitorLG 34" Ultra Wide3440x1440
    Storage #14ea 960 Pro 2TB, 2ea 970 Evo 2TB
    Storage #21ea 960 Pro 1 TB, 1ea 970 Pro 1TB
    CPU CoolerEKWB CPU, Swiftech Res/pump, 400mm Rad
    CaseThermaltake View 91
    Power SupplyNZXT Hale 90 1200W
    Keyboard Logitech G910
    Mouse Razer Ouroboros
    OS W10 64 1809, 1903, Ubuntu Linux
    Network RouterNetgear R9000 + 4ea R9000 AP's, 10 Gb Switch
    Accessory #1 Hyper M.2 X16 V2
    Accessory #2 10GB network via Intel 550 Nic
    Accessory #3 2 10GB Asustor NAS 7000 series
    Jan 2013
    12
    246
    I quit using air coolers a few years ago because they were noisy, hard to mount, and blocked access to the motherboard and other accessories.
    I use the Kraken X62 now. It's easy to mount, allows full access to the MB, and basically runs at a quiet idle even when gaming.
    I run an AMD Vega 64 Liquid GPU which also runs quiet.
    I make sure to purchase cases which allow room for the radiators and fans for the GPU/CPU. GPU mounts on the rear and CPU mounts in the top.
    I also use a 1200w psu which runs cool and silent.
    My R6 Apex has 8 NVME drives onboard using the HyperX16 card so there are no Sata drives in the case requiring cooling.
    An exremely fast and quiet system.
    ROG Member Array
    Aug 2018
    9
    Thanks everyone, great input all. Sir Abaidor, that is exactly what I'm looking for. It will be just for test booting my R6E before I start the main build and also for those unexpected time when you just need a good heatsink and fan.
    If you guys have any other Air Cooler recommendation for the RampageVI and the Strix please add them here I'm sure other may find this information useful. Big Mahalo peps
    Sep 2012
    150
    I would 100% recommend the Noctua-NH-D15S which fits perfect to the first pci-e slot on most/all asus mobo's!
    Best temps, best build quality and easy to install (got 6 or more coolers from noctua in the past).
    BUT:
    If you want real low temps you need to delid your cpu:
    My 7980XE had on two cores a max temp of 86 degree.
    After delid the cpu & Conductonaut (with noctua) the temperature was max. 59 degree (@ 30 degree room temp!!)
    Tested with 1 1/2 hours Aida64 stresstest.
    If you want to see my pics:
    https://www.computerbase.de/forum/th...#post-21363034
    Intel Core i9-7980XE @ Noctua NH-D15S | ASUS ROG Rampage VI Extreme | MSI GTX 1080 Ti Lightning Z SLI | G.Skill 128GB RAM, DDR4-3200, CL14 | Samsung SSD 960 PRO 2TB | 2x Samsung SSD 840 PRO (512GB) + 2x Samsung SSD 830 (512GB) | Plextor PX-L890SA | Corsair AX1500i Titanium | Lian Li TYR PC-X2000F @bequiet Silentwings USC |
    Intel Core i7-6950X @ Noctua NH-D15S | Asus ROG Rampage V10 Extreme | MSI GTX 1080 Ti Lightning Z | Kingston 128GB RAM, DDR4-2666, CL15 | Seasonic 1.000 Platinum |
