Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    New ROGer Array
    Aug 2018
    2
    Strix hero gl503ge fan GPU problem
    Hello,
    I'm a new user of ASUS ROG GL503GE
    i had a problem with my GPU Fan Speed, it shows 5000 rpm when idle (really noisy)
    i've tried to install GPU Tweak II but i can't control my fan speed that program doesn't show fan speed control
    also i tried to install MSI Afterburner but fan speed % control is in locked mode
Name:	GPU SPEED 5000.jpg
Name:	GPU TWEAK.jpg
    ROG Guru: White Belt Array
    Jul 2018
    11
    120
    Cooling system doesn't differentiate CPU|GPU vents control.
    Please use ROG Gaming Center.
    New ROGer Array
    Aug 2018
    2
    Quote Originally Posted by McCoy View Post
    how to use ROG Gaming Center ? i know there is an option about fan overboost but whether i set it to silent, the GPU fan is not slowing down.
Name:	fan overboost.jpg
    Jul 2018
    11
    120
    Well, in my case i had a slider (25-100%) in RoG Gaming Center. Please write ASUS technical support directly in online chat on their web-site.
    New ROGer Array
    May 2018
    1
    I have a ROG GL503GE strix. Im encountering the same problems. GPU fan constantly revs up and down and sometimes gets stuck at 100% speed even during idle. I can no longer control the fan speed using gaming center. Have you found a fix for this?
    ROG Guru: Orange Belt Array FULLMETALJACKET7's Avatar
    Mar 2018
    46
    454
    Quote Originally Posted by mariozamoramd View Post
    Open the laptop back cover, then carefully unplug the fan connectors, then plug them back in. That's probably a bad connection with the rpm "sensor" wire. If the main board loses its signal, the fan goes full speed.
  7. #7
    New ROGer Array
    Sep 2018
    4
    I have the same issue.. please if you fixed it let me know HOW!
  8. #8
    New ROGer Array
    Oct 2018
    2
    Quote Originally Posted by FULLMETALJACKET7 View Post
    Was this effective? any updates on this?
  9. #9
    ROG Member Array
    Jun 2018
    14
    I have had the same problem a few weeks ago. Try updatimg your BIOS, or flash it with asus EZ flash. That was the only thing that worked for me. I cleaned the fan, reset windows, unistalled stuff, etc. Flashing the BIOS was the only solution.
  10. #10
    ROG Member Array
    May 2018
    22
    What version of the BIOS are you using now? I'm having this damn problem, tried with BIOS 312, 313 and 314.
Tags for this Thread
