I need some help with maximizing my AURA setup - ROG CROSSHAIR VII HERO (WI-FI)
SteelZAlloy
Hi all,
I need some help with maximizing my AURA setup.
Here are my components:
I have ROG CROSSHAIR VII HERO (WI-FI) motherboard:
https://www.asus.com/Motherboards/ROG-CROSSHAIR-VII-HERO-WI-FI
Antec DF500 RGB case:
http://store.antec.com/dark-fleet-series/df500-rgb.html
AIO cooling - Antec Mercury 360 RGB (this component is declared to have AURA support):
https://antec.com/product/cooling/m360-rgb.php
Here is my request:
How should I modify the front fans connections of the case so I will be able to control them from the AURA software?
Right now they are connected with control using a button on the case.
How should I modify the connection on the AIO? right now I'm using the control that came with the AIO solution.
I have plenty of 4-pin PWM/DC fan connections on the MB and 2 AURA RGB headers
Link to the MB manual:
https://dlcdnets.asus.com/pub/ASUS/mb/SocketAM4/ROG_CROSSHAIR-VII-HERO_WI-FI/E13834_ROG_CROSSHAIR_VI...
Please notice that I'm newbie to RGB connections, so I really would appreciate clear instructions.
Thanks ahead.
cl-Adrian
SteelZAlloy wrote:
Hi all,
Here is my request:
Thanks ahead.
Try connecting your case fans directly to you motherboard (4-pin PWM/DC).
Try updating and syncing your devies on Aura.
Please PM or email me with the below details so I can work with related personnel to get this straightened out.
My email is cl-adrian@asus.com.:
