Results 1 to 7 of 7
    ROG Enthusiast Array
    Jun 2018
    26
    Does anyone with a GL703G laptop NOT have coil whine?
    I'm getting ready to RMA my laptop for a 4th time. But I don't know if ASUS even has working hardware out there, no need to RMA it if ASUS has no ability to fix it.
    So if you have GL703 laptop, do you hear the following: When both the CPU and GPU fans turn off, you are plugged in running in high performance mode, do you hear a scratchy/screechy sound, near the 6 key or near the main speakers above the function keys? Do you hear it getting worse when you move the mouse across the screen?
    ROG Guru: Orange Belt Array FULLMETALJACKET7's Avatar
    Mar 2018
    46
    492
    I think asking if someone hears coil whine is like asking them if they have input lag. Different people will report different results, specially regarding coil whine. Many people can't hear it because of their age or simply because they have bad hearing. I know for a fact that my GL502VSK has coil whine, I can clearly hear it specially when moving the mouse, but my wife can't.
    Same goes for input lag. I have a friend who can barely tell the difference between 40 to 60 fps, let alone input lag.*
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    Quote Originally Posted by FULLMETALJACKET7 View Post
    Many people can't hear it even at "prime" age with "perfect" hearing. Coil whine is not a yes/no thing, the noise is always present to some degree in every oscillator - it's judged (by the manufacturer) to be "inaudible", at least to most people most of the time and with most devices under normal usage.
    "Psychoacoustic" effects are variable and unique for each one of us, imperfect semiconductor qualities are variable and unique for each manufactured part or assemblage of parts. Sometimes all these parameters match up in the worst possible combinations.
    And, of course, operating things out of rated spec (ie: overclocking, overvolting, undervolting, excess heat) puts more electrical stress on the parts - coil-whine is sometimes a good barometer for indicating when your hardware is starting to redline.
    Pre-emptive answer to the question which will be asked:
    No, ASUS warranty does not normally cover coil-whine (unless it explicitly says so).
    But yes, ASUS will still sometimes accept RMA for reported coil-whine. At their discretion. Especially if it seems particularly noxious.
    It can help a lot (and certainly won't hurt) if you can submit some sort of audio or video recording which demonstrates the coil whine. And if you can explain why you find it offensive or unacceptable.
    Also, google offers plenty of "solutions" and workarounds for coil-whine. Some of which may seem inglorious and low-tech, but are still effective enough often enough (and cheap enough) to be worth trying. Beware that some of these approaches may void your ASUS warranty.
    [/Korth]
    ROG Member Array
    Aug 2018
    Coil whine GL703GM
    I can only hear it when I put me ear right up to the keyboard of the laptop otherwise it's not noticeable during normal use, and I think my hearing is pretty good for these sort of things. Sounds like you might have got a bad egg unfortunately, just hope you're not having the battery draining issues I and others are having.
    ROG Member Array
    Jun 2018
    14
    I hear a little bit. Not enough for it to be annoying or to be heard with headphones on, though, my left ear drum got perforated a couple years back and I have tinnitus in it.
    ROG Member Array
    Sep 2018
    6
    Same issue on 2 units i got from a reseller. I dont think this is notmal, never encountered anything like it on any other laptop (i fix laptops), and previous generations of rog laptops didn't have this issue, as least those I owned.
    It may be okay on a graphics card in a desktop, but when you are only a few feet away from the screen all the time, its very annoying...
  7. #7
    ROG Member Array
    Mar 2020
    6
    My laptop is Asus Rog GL704GV and it has coil whine. I managed to get rid of it. So my solution is when I am on balanced mode /switched by armory crate/ to go to windows power options = high performance = change plan settings = change advanced power settings = processor power management = minimum processor state /change to less than 100%/ I put 50 %. Now there is no coil whine. Same operation to the other silent mode, turbo mode etc....
